GSR RUNNING ON 2CYL WTF?!
Old Sep 28, 2006 | 09:00 PM
AdamB18C1EK's Avatar
Default GSR RUNNING ON 2CYL WTF?!
okay i swapped my hatch with an obd2 gsr. Its on obd1 p72 its been running suprisingly well recently but now all the sudden it started running on 3 cyl. then leaving a friends house it started running on 2!!! i was getting on the interstate not going fast at all. and i heard a backfire....then like 5 minutes later i could tell i was running on 3cyl... so i took it to a friends house and we figured i needed new plugs because it was getting spark on all cyls. so i changed the plugs and still runs like crap. then it seemed as if the number 2 AND 3 cylinders werent doing ****. i unplugged the number 3 injector and it did nothing at all, there was no difference in the idle what so ever. HELP PLEASE IM HONDA RETARDED!!!!
Modified by AdamB18C1EK at 2:15 AM 9/29/2006
Old Sep 28, 2006 | 09:44 PM
VRD^don's Avatar
Default Re: GSR RUNNING ON 2CYL WTF?! (AdamB18C1EK)
recheck all your wiring...double check..back track..something might of gotten loosen...any cels??
Old Sep 28, 2006 | 10:14 PM
no cels.... all the injectors are plugged in. everything electical seems to be up to snuff. my throtte response is freakin horribleeeee!!!
Old Sep 29, 2006 | 04:27 AM
HELP MEEEEE
Old Sep 29, 2006 | 04:14 PM
Jarfal's Avatar
it could be wiring, fuel or cylinder compression.
Old Sep 29, 2006 | 10:04 PM
LINKIN024's Avatar
Default Re: (AdamB18C1EK)
check to make shure spark plug wires are pluged into the distributer correctly
Old Sep 30, 2006 | 04:33 AM
Dogginator's Avatar
Daisy... Daisy...
Check the injector wiring for a signal on cylinder 3. If you have a signal, you either have a bad injector or a clogged injector.
GagnarTheUnruly
Engine Management and Tuning
Sep 23, 2017 07:09 AM
BoldFart16
Jul 4, 2011 11:51 AM
BUILTandBOOSTED
Jun 3, 2008 02:30 AM
Brian77769
10
Feb 9, 2006 03:33 AM
Nickyj1211
Nov 29, 2004 03:03 PM
