no fire WTF?
Old Sep 28, 2006 | 08:48 PM
dustinO's Avatar
Default no fire WTF?
K so I got my JDM D15B swapped in today....everything went pretty smooth
Car cranked just fine. But the it would not fire up.
Checked for fuel and spark and they are both there. Made sure everything was grounded fine. and it was..So we have fuel and spark, what else?
I am running a Automatic PO8 ECU. We ended up wiring the o2 sensor straight into pin A6 on the ECU. little confused here. Any ideas would be awesome
Old Sep 28, 2006 | 09:18 PM
Texas_EG's Avatar
sounds like your distributor is fried, and maybe your ecu is no goood ...check all wireing.
Old Sep 28, 2006 | 10:01 PM
4dohs4mohoes's Avatar
Default Re: (Texas_EG)
Double check the firing order.
Old Sep 28, 2006 | 10:57 PM
dustinO's Avatar
If the dizzy was fried then I wouldn't be getting a spark
I'm thinking either bad gas or clogged injectors
Old Sep 29, 2006 | 04:13 AM
SLO Sol's Avatar
Default Re: (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees &raquo;</TD></TR><TR><TD CLASS="quote">Double check the firing order. </TD></TR></TABLE>
Old Oct 4, 2006 | 10:47 AM
dustinO's Avatar
Checked today and the firing order is perfect.
I noticed that there are 3 plugs that dont seem to go anywhere. they are on the section of the harness that run back by the firewall. 2 of them are circular and the wires consist of 1.pinkW/blue stripe and yellow W/green stripe 2.green W/blue stripe and Red W/ yellow stripe.... Then the third one is a bigger one that is square shaped and has 4 wires running out of it....
Everything seems fine other then that
Old Oct 4, 2006 | 01:50 PM
dustinO's Avatar
OK so I narrowed it down to fuel
I am getting fuel in the fuel rail. but it's not coming out of the injectors. I really doubt that they are all clogged up. I'm thinking this could be because of one of the wiring harness clips that is not plugged in? anyone?
CivicCpeEX
Jul 11, 2010 07:59 PM
thrty8street
15
Apr 18, 2006 02:46 PM
BALLIN H22 EK
Feb 24, 2006 12:36 PM
gambo117
Aug 6, 2005 03:40 PM
99 honda civic
Feb 1, 2005 03:13 PM
