stock fuel psi?
i want to know what is the stock fuel pressure psi, so i know what to bump my fuel pressure,,,its at 45 psi right now, but don't know where to leave it at, i tried it at 38 psi and lags alooot, i left it to 45 where it is right now, and it still lags...what do you guys think i should do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">what do you guys think i should do?</TD></TR></TABLE>
Ummm, get a real fuel management system and some dyno time.
my friend installed an intake manifold on my car last night, and he bumped the fuel, i believe at 50 psi with the vacuum hose off, and when on, it reads 40 psi...i told him it might be too much but said that, that's where it's supposed to be at,
omg it was hectic today, we installed the manifold last night fuel was at 45 psi,(b&m BTW) after reading hear on HT they told me it was too high, so this morning i lowered it to around 40 psi,(with the vacuum off) which was lagging alot, so i was cruising down the highway today and came to a stop, then suddenly my radiator just shot out like crazy, all the water just came out, it was like a geyser, so i took it to my friend and he told me that the motor was forcing itself because the fuel pressure was too low, so that's was caused my radiator to go out, so luckily my friend has a eg with a b16 that is totaled and we took his radiator just so i can go home...the fan switch didn't go on so we wired it directly to the battery....
how is this for a Thursday night?????!!!!!!!!!
so as of now, the fuel is at around 48-50 psi with the vacuum off and 38-40 with the vacuum on
EDIT: my set-up is this....
CTR pistons
dc 4-2-1 header
apex 2.25 cat-back
straight pipe
blox intake manifold
cold-air
b&m fpr
f&S stage 2 clutch
itr flywheel
so psi too much?
how much should my psi be at with this setup?
CTR pistons
dc 4-2-1 header
apex 2.25 cat-back
straight pipe
cold-air
b&m fpr
f&S stage 2 clutch
itr flywheel
so psi too much?
oh and i know you guys are going to tell me to go tune it, but dont i need an obd1 and chipped with hondata or crome or anything that they can tune it with? i mean, i cant go and tune the damn thing with the stock ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">oh and i know you guys are going to tell me to go tune it, but dont i need an obd1 and chipped with hondata or crome or anything that they can tune it with? i mean, i cant go and tune the damn thing with the stock ecu</TD></TR></TABLE>
Yeah, you do.
Yeah, you do.
gnar kill
May 3, 2006 10:55 AM
blue_hatch
Mar 6, 2005 11:39 PM
