Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
New stoppers....Type R clappers....
Old Sep 28, 2006 | 03:48 PM
5hifty_ES1's Avatar
Default New stoppers....Type R clappers....
Hey everyone, me again... So i was lucky enough to get Type-R clappers to upgrade shitty braking.. Well enuff chit chat, heres pics...
new jackstands...lol, R-clappers and KVR discs
my painted Integra Typer R clappers, tried to stay away from red but i think i will redo them.....
Thermo paint...from what i gather it changes color with amount of heat and you can decide whether or not ur pad compound is too aggressive or not....better explanation later..
Mock up....sexyyyy...
11.2mm KVR discs with new "J" slots, not as aggressive on pads like regular slotted rotors and will not crack like cross-drilled.....vs. to heavy *** 12 mm AEM rotors (might sell them)
might as well clean and regrease the sliders...
Werkin' away.....
JDM flip flops for ultimate toe protection..
pops in on the action...
comparo....oem vs. new setup...
no pics of after yet.....but ive eaten my steering wheel a couple of times and i love itttt!!
Major props going out to Telly for the clappers, and to my boy Chris from Stagefourmotorsports for the discs!!!!
Old Sep 28, 2006 | 04:07 PM
Vantage's Avatar
damn man, VERY nice looking brakes. I love em.
Old Sep 28, 2006 | 04:24 PM
Boilermaker1's Avatar
Looks like you forgot to grind the mounting brackets.
Old Sep 28, 2006 | 05:11 PM
5hifty_ES1's Avatar
Default Re: (Boilermaker1)
Hey boilermaker, actually i didnt forget, i did grind them but i guess you cant see them since i painted them after...or else i wouldnt be able to mount them.
Old Sep 28, 2006 | 05:59 PM
fventura03's Avatar
dc2r calipers fit? wow...
Old Sep 28, 2006 | 06:07 PM
WorldsSlowestEm2's Avatar
are those dc5-r or dc2-r calipers??? And they fit with your 4-lug???
Old Sep 28, 2006 | 06:17 PM
K20me's Avatar
Default Re: (WorldsSlowestEm2)
boilermaker1 was the first one to do this, if I remeber correctly. Nice!
Old Sep 28, 2006 | 07:04 PM
Default Re: (5hifty_ES1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hifty_ES1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey boilermaker, actually i didnt forget, i did grind them but i guess you cant see them since i painted them after...or else i wouldnt be able to mount them. </TD></TR></TABLE>
They will fit on there, the rotor won't turn.
Hard to tell with the paint I guess, and because I'm not sure which side of the bracket I'm looking at with it all disassembled, its been almost a year since I did it, so the details of what I did are getting fuzzy. I do remember that you'll end up cutting the backing plates off. The rotors are a bit more offset than the stock ones, and they'll rub the backing plate behind the hub, its so close to where its bolted into the spindle I never could get it to bend back and stay, so I just hacked it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20me &raquo;</TD></TR><TR><TD CLASS="quote">boilermaker1 was the first one to do this, if I remeber correctly. Nice! </TD></TR></TABLE>
Whether or not thats true, I'm not sure, but I did it last fall.... its a fantastic cheap upgrade.
Old Sep 29, 2006 | 01:25 PM
Earthworm Jim's Avatar
Default Re: New stoppers....Type R clappers.... (5hifty_ES1)
very, very nice, I like it, never seen it before
Old Sep 29, 2006 | 02:43 PM
toyomatt84's Avatar
Sanji
Nice, clean install there.
Old Sep 30, 2006 | 06:38 AM
fventura03's Avatar
very nice. heard about it, just wasn't sure. which rotors did you guys use?
Old Sep 30, 2006 | 06:55 AM
Prelude rotors, redrilled. Fastbrakes sells em.
Old Sep 30, 2006 | 01:08 PM
hondaluver's Avatar
nice... don't you mean 11.2 inches and 12 inches instead of mm
Old Sep 30, 2006 | 01:10 PM
fventura03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">Prelude rotors, redrilled. Fastbrakes sells em.</TD></TR></TABLE>
by redrilled you mean, drill for 4x100? from 4x114.3?
edit: nm, i saw telly's post on 7thgencivic. for future reference, you need a 93ish (4x114.3) rotor and redrill it for 4x100.
Old Sep 30, 2006 | 01:57 PM
Curiouz_G's Avatar
i like. i want em!
Old Sep 30, 2006 | 02:33 PM
toyomatt84's Avatar
Sanji
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">by redrilled you mean, drill for 4x100? from 4x114.3?
edit: nm, i saw telly's post on 7thgencivic. for future reference, you need a 93ish (4x114.3) rotor and redrill it for 4x100.</TD></TR></TABLE>
You should be able to use any 4x114.3 rotor of similar size to that of the 11.2in Accord one's used here.
Old Sep 30, 2006 | 05:48 PM
yes, you essentially make a universal 4 lug rotor. You can commercially buy them, I wouldn't recommend making them yourself without the proper machine tools to get them centered right.
4th gen prelude rotors, accord V6 rotors or DC2R rotors will all work with the single pot calipers. if you go for the 2 piston (NSX or legend) setup, you need the heavy duty rotors (from a Legend, they're thicker).
Old Jul 13, 2008 | 10:02 AM
themachinist's Avatar
From: Big desert next to Cali, United States of America
I want KVR discs like he is using but I don't want to swap over to prelude discs and dc2r clappers. Are our cars acura el where the company is based?
if so is it these discs:
http://kvrperformance.com/shop...12338
Old Jul 13, 2008 | 10:43 AM
burke420's Avatar
so is this a lil bit better than the oem setup... bc i hate mine and if this will fit 16" RPF1s im down!
Old Sep 18, 2008 | 06:33 PM
nichjon's Avatar
Hi there, I own a 2005 Civic ES5 and would like to seek your help with rgds to brake upgrade. Is it possible for my car to use a bigger rotor and calilper setup from another Honda car such as a DC5 as i need my car to still "look" as stock as possible cos they're very strict in Singapore with rgds to car mods, especially performance mods. I'm looking for a quick direct bolt-on solution if possible. I think my current front discs are only 260mm or something this size, and I'm looking at least to use about 300mm discs. Thanks a mil!
Old Sep 18, 2008 | 11:00 PM
01_civic's Avatar
dam....thats pure sex! love it!!!
Old Sep 19, 2008 | 09:46 AM
efficiencyJunkie's Avatar
Default FV-QR
You guys tracking your cars and finding the upgraded needed?
Good brembo blanks + super blue + good pads did the trick. Altho power regeneration in my car slows me down too. haha
edit; brakes look great on the car man! Can you do a "what it cost" break down for us?
Old Mar 14, 2016 | 06:16 AM
Bo Sprocket's Avatar
does this mean i can swap on legend calipers and rotors on to stock d17 hub, and retain 15" rims? are legends 4 or five lug?
Old Mar 14, 2016 | 10:00 PM
toyomatt84's Avatar
Sanji
The caliper needs to be machined to be centered over the rotor, and you'll need something like a TSX rotor for proper fitment (redrilled if you keep your factory 4x100 layout).
Old Mar 15, 2016 | 04:10 AM
thanks again toyomatt84, would the legend calipers fit on rsx (non s) hub/knuckles? on 16"s ? as i also want to do a tire upgrade any idea which wheel and tire combo would be closest to stock 205/15/60 or 205/16 /60?
