Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside.
Old Sep 28, 2006 | 01:34 PM
Suzukii's Avatar
Default Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside.
hi guys,
I'm planning to run some 13inch wheels on my ITR. Can i swap the civic front hubs over to the ITR? Any particular ones that won't fit? Thanks!!!
Old Sep 28, 2006 | 01:38 PM
GO-FIGHT-KILL's Avatar
Why oh why would you change out Type-R hubs to accomidate for 13" wheels? I'd REALLY like to know what you're doing, because I'll trade you my some LS hubs for you ITR ones.
Old Sep 28, 2006 | 01:50 PM
Mugen Mike's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">Why oh why would you change out Type-R hubs to accomidate for 13" wheels?</TD></TR></TABLE>
Duh! To fit dem Daytons h0may!
Old Sep 28, 2006 | 02:20 PM
96ls's Avatar
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Duh! To fit dem Daytons h0may! </TD></TR></TABLE>
you're not right mike.
Old Sep 28, 2006 | 02:47 PM
Suzukii's Avatar
well, yeah i know what you mean. I'm using 13inch drag slicks so i've to find a hub that will fit those 13 inches.
Old Sep 28, 2006 | 03:27 PM
Suzukii's Avatar
Default Re: (Suzukii)
any idea?
Old Sep 28, 2006 | 03:30 PM
Madspeed's Avatar
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (Suzukii)
yes...the civic parts will work...however you may lose ABS unless you use ABS hubs, and as well your not gonna stop for ****, but, to answer the question it will work.
too funny....
Old Sep 28, 2006 | 04:29 PM
R you serious's Avatar
1'' wheel spacers!
on a side silly note for my fellow track ******, 13'' wheels = instant 5.0+ final drive! just need to get some serious brake ducting.
Old Sep 28, 2006 | 04:33 PM
Larkin W.'s Avatar
Dat Ish is Dope y0!
Old Sep 28, 2006 | 04:36 PM
Suzukii's Avatar
Default Re: (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">1'' wheel spacers!
Can you explain in more detail please? thanks
Old Sep 28, 2006 | 06:18 PM
redzcstandardhatch's Avatar
something different
couldnt you just swap on regular integra knuckles?
Old Sep 28, 2006 | 06:24 PM
BlueIntegraBoy's Avatar
Default Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">couldnt you just swap on regular integra knuckles? </TD></TR></TABLE>
Yes and no.
Yes, he can but won't be able to run 13" rims.
But he can however swap over 92-95 Civic DX knuckles, but will have problems with ABS.
Old Sep 28, 2006 | 07:28 PM
01-0720's Avatar
Default Re: (BlueIntegraBoy)
are 99-00 civic si and dc gsr brakes the same size?
if so you can use 13'' lenso drag wheels, they fit on my buddies 99 si no problem
but since 99 si's dont have abs, you could use gsr front hub/brakes, im pretty sure there the same size
Old Sep 28, 2006 | 08:12 PM
Default Re: (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">are 99-00 civic si and dc gsr brakes the same size?
but since 99 si's dont have abs, you could use gsr front hub/brakes, im pretty sure there the same size</TD></TR></TABLE>
They are
Old Sep 28, 2006 | 08:28 PM
RPRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suzukii &raquo;</TD></TR><TR><TD CLASS="quote">hi guys,
Do you already have them? Is there a particular reason why you are using 13"s instead of 15"s? I have no problem using 15" slicks on my R with the 5 lug. I do think it would be best to just get a whole dx setup and bolt it on the car. Dont even ruin the ITR hubs. just get the whole assembly and be happy
Old Sep 28, 2006 | 10:16 PM
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (RPRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">
Do you already have them? Is there a particular reason why you are using 13"s instead of 15"s? I have no problem using 15" slicks on my R with the 5 lug. I do think it would be best to just get a whole dx setup and bolt it on the car. Dont even ruin the ITR hubs. just get the whole assembly and be happy</TD></TR></TABLE>
yah seriouly, im sure the whole suspension components can be had for like a hundred bucks.
1'' wheel spacers that you want me elborate on. well i cant. its exactly what i said
Old Sep 29, 2006 | 02:39 AM
Suzukii's Avatar
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (R you serious)
thanks for the info guys,
So i will need the control arms and all the other bits to make it work right? I can't just swap in the dx hubs and use the original integra control arms?
yeah, 13inch slicks already ordered and wheels too...
Old Sep 29, 2006 | 02:52 AM
Reid's Avatar
Global Moderator
Just swap the complete spindles and you're done.
Old Sep 29, 2006 | 05:40 PM
94rs-turbo's Avatar
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Just swap the complete spindles and you're done. </TD></TR></TABLE>
yeah no reason to 'tear yours appart" just find a reg integra 4 lug set up and there you
Old Sep 29, 2006 | 07:01 PM
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">
yeah no reason to 'tear yours appart" just find a reg integra 4 lug set up and there you</TD></TR></TABLE> a reg 4 lug integra is too big...
civic is what he needs. anyhow hes not tearing it apart. its 3 ball joints...
Old Sep 29, 2006 | 08:39 PM
boosted94cx's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote"> a reg 4 lug integra is too big...
civic is what he needs. anyhow hes not tearing it apart. its 3 ball joints... </TD></TR></TABLE>
you can fit lenso's or welds on integra brakes with no issues
Old Sep 29, 2006 | 09:03 PM
floatfisher's Avatar
LMAO THATS FUCKEN HILARIOUS!!
maybe buddy wants to put hydro's on and ride on 10's gangsta stylz
Old Oct 4, 2006 | 03:15 PM
Suzukii's Avatar
Will my integra R driveshafts fit into all civic hubs? I know the DX driveshafts are tiny thin. Just not sure if the CV joints are the same size. If the Integra type R driveshafs will fit into all civic hubs then it'll be easy. Can someone confirm this info for me please?
thanks!!!
Old Oct 4, 2006 | 04:14 PM
Real_E-AT's Avatar
I'm assuming you wanna do something like this?:
Old Oct 4, 2006 | 05:33 PM
gsrboy171
Guest
Posts: n/a
Default Re: Can civic 4x100 hubs be fitted to JDM ITR's front? Reason inside. (ChopSuey)
lenso make's 5lug 13in for drag tires. should have search before you buy.
