Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Check your power steering!
Old Sep 28, 2006 | 12:47 PM
R18A1FG's Avatar
Default Check your power steering!
I work at a honda dealer in southern Michigan and just to inform everyone in the last couple months we have been replacing numerous plastic elbows off the power steering resevoirs, so just keep an eye out for leakage, one civic had obviously been leaking a while and we had to put a rack in it as well. of course it will be covered under your warranty!
Old Sep 28, 2006 | 12:55 PM
Declectic's Avatar
Default Re: Check your power steering! (R18A1FG)
good lookin out on the info
does this apply to FG1 and FG2 or just one or the other?
Old Sep 28, 2006 | 02:36 PM
Demonis's Avatar
hm, no probs here yet.
Old Sep 28, 2006 | 03:29 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (Demonis)
its mainly for all 06 civic. 4 door and coupe.. no si yet at our dealer.. so..and it leaks from the pump not resivor
Old Sep 28, 2006 | 04:07 PM
misterghost's Avatar
any pic?
Old Sep 28, 2006 | 05:10 PM
SpoolnG2's Avatar
Default Re: (misterghost)
I thought there was no power steering pump on the Si b/c it was electronic???
Old Sep 28, 2006 | 05:14 PM
SpoolnG2's Avatar
Default Re: (SpoolnG2)
Here we go, right from the specification page on honda's website about the Si.
http://automobiles.honda.com/m...ic+Si
Its the third row of boxes, 6th one down.
Old Sep 28, 2006 | 05:36 PM
TRE_'s Avatar
EPS is standard on the Si only, FG1 civics are equipped with traditional PS which has a resiovor, pump, etc... I've had 2 come in to my shop that had small leaks which is warrantied and fixed with a simple piece and one which required a whole new rack because the owner didnt notice the leak soon enough.
FG2's wont be effected and only a small amount of FG1's will require attention
Old Sep 28, 2006 | 07:20 PM
Solo2Vtec's Avatar
Default Re: (TRE_)
Can you give us a head's up on other problem area's on the si etc? For example I have had my si for a month and I have a terrible noise coming from the rear passenger area. I can't tell if its a shock or body panel loose. Have heard of this before? thanks in advance
Old Sep 28, 2006 | 07:25 PM
SteaveO2's Avatar
Default Re: (Solo2Vtec)
There's no rear body panel that could be loose. Unless u consider the bumper or trunk rear body panels. The rear quarter panels are welded on.
Anyways, there's been people having problems with noises in the rear and it's the shocks.
Old Sep 29, 2006 | 03:59 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (SteaveO2)
i can tell u we havent had any problems with the si yet.. no ps leak at all neither
Old Sep 29, 2006 | 04:24 AM
R18A1FG's Avatar
Default Re: (ek9bmxer)
NO OF COURSE THERE ARENT GOING TO BE PS LEAKS ON THE SI, AND THE DOZEN OR SO WE HAVE HAD IN HERE HAVE *BEEN LEAKING FROM THE PLASTIC ELBOW OFF THE RESEVERVOIR* HONDA PART NUMBER FOR THE ELBOW IS 56123-RNA-A01, AND OF COURSE THE O-RING THAT GOES INTO THE ELBOW.
Old Sep 29, 2006 | 04:26 AM
R18A1FG's Avatar
YEA ANYTHING I FIND OUT I WILL MAKE SURE TO POST IN HERE, THE SI IS PRETTY MUCH BULLET PROOF, MAYBE SOME QUIRKS WITH THE PANELS AND RATTLES BUT AS FAR AS THE ENGINE ITS NOT A NEW BREED, ITS JUST A MUCH BETTER VERSION OF AN OLD BREED.
THE R SERIES MOTORS AND DRIVETRAINS AND EVERYTHING ARE ALL NEW SO THERE MAYBE A FEW STUPID THINGS.
ILL BE SURE TO LET YOU KNOW!
blackb16209
Dec 24, 2006 04:57 PM
bgcrx
Northern California (Sales)
Aug 23, 2006 03:23 PM
SeeD419
May 31, 2006 11:50 PM
abraunworth
Mar 29, 2002 11:50 AM
