gsr block
I want to build a gsr block is it better if I put CTR piston or Type R pistons Ive notice that the compression is higher on the CTR pistons than the type Rs also the head which one gets more hp the type R head on GSR block or just a gsr head...HELP
lol sorry have to do it......... whats the differnce between type R and ctr? they are the same thing
ctr=civic type r.... itr= integra type r........... sorry......... i know what you mean though itr or ctr....... the ctr's will give you a much higher c/r but the same power could be made with the itr's becuase you will actually be able to run a good amount of timing on pump gas
as far as heads i would go with the itr....... but im biased
ctr=civic type r.... itr= integra type r........... sorry......... i know what you mean though itr or ctr....... the ctr's will give you a much higher c/r but the same power could be made with the itr's becuase you will actually be able to run a good amount of timing on pump gasas far as heads i would go with the itr....... but im biased
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">in not a big fan of ctr pistons
too much compression for eveyday driving.
i go with p30
they will give you more compression than itr pistons</TD></TR></TABLE>
I am also not a fan of the CTR PCT piston, but Do you have ANY proof to this statment in bold?
ITR = P73
CTR = PCT
i go with p30
ITR = P73
CTR = PCT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRiXZc »</TD></TR><TR><TD CLASS="quote">
ITR = P73
CTR = PCT</TD></TR></TABLE>
depends on a few factors, see for yourself: http://www.zealautowerks.com/
ITR = P73
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky »</TD></TR><TR><TD CLASS="quote">
depends on a few factors, see for yourself: http://www.zealautowerks.com/</TD></TR></TABLE>
Ok you question me and make my point,
Modified by CRiXZc at 8:18 PM 9/28/2006
They are designed for NA applications with a Compression ratio of
B16A Block and Head 10.95:1
B18C1 Block and Head 12.40:1
B18C1 Block and B18c5/B16A Head 12.10:1
B18A/B Block with B18C1 Head 12.64:1
thats just what I found to prove it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERNIEinDAteg »</TD></TR><TR><TD CLASS="quote">They are designed for NA applications with a Compression ratio of
Are you calculating CTR PCT compressions? If so they are much higher in each application. You must factor in the piston compression height.
</TD></TR></TABLE>Are you calculating CTR PCT compressions? If so they are much higher in each application. You must factor in the piston compression height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky »</TD></TR><TR><TD CLASS="quote">depends on a few factors, see for yourself: http://www.zealautowerks.com/</TD></TR></TABLE>
What is funny is you sealed your own fate. Check for yourself.
P30's in my engine equals 11.5:1. P73-00's in my engine equals 11.59:1. I like that calculator though. Only one I have seen so far that actually factors in compression height and true piston-to-deck height which is key. Everyone always thinks P30's will yield more compression based on dome displacement alone, but there are other factors as shown.
