did compression test...f&%$!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">A leakdown test would give you a better idea what the issue is.
How many miles are on the motor?</TD></TR></TABLE>
86k
86k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Did you add a small amount of oil to the cylinders and redo the compression test? This will confirm if your rings are the leak path.</TD></TR></TABLE>
he did the compression test 2 times without adding oil.
why does the oil actaully show better results?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">Yep my compression is 230 across and i burn triple what you do. If the engine is running fine then i would let it be. One quart in 3000 miles is nothing to worry about.</TD></TR></TABLE>
but still isnt 160 bad for compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">
why does the oil actaully show better results?</TD></TR></TABLE>
The oil will temporarily seal mildly leaking rings and boost the compression reading. It only helps if the rings are the problem.
but still isnt 160 bad for compression?</TD></TR></TABLE>
Don;t worry about the ultimate number because the compression tester can significantly affect that. The difference of 30 psig between cylinders is cause for concern. Have you misshifted recently?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">The oil will temporarily seal mildly leaking rings and boost the compression reading. It only helps if the rings are the problem.
Don;t worry about the ultimate number because the compression tester can significantly affect that. The difference of 30 psig between cylinders is cause for concern. Have you misshifted recently?</TD></TR></TABLE>
hmmmm on the freeway onramp i redlined 3rd gear and i hit the clutch to do a slow shift but i didnt hit the clutch all the way in so it kind of grinded and didnt go into gear and it didnt bounce off the limiter.
For a misshift to matter, it is typicall 3rd gear at redline downshifting to 2nd for an overrevving, exhaust valve bending experience. I brought up a misshift because it is a common way to lose compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">For a misshift to matter, it is typicall 3rd gear at redline downshifting to 2nd for an overrevving, exhaust valve bending experience. I brought up a misshift because it is a common way to lose compression.</TD></TR></TABLE>
i never went from 3rd redline to 2nd before.
RedRacerCivic
11
May 22, 2003 10:29 AM
