B-series Crank Question
I recently acquired a crank from my friend and i need to verify that is out of the motor he claims...how do i distinguish between teh b-series cranks? Also need to know how to distinguish from sohc...should i test a rod on the crank? Help please
SOHC vs DOHC differences:
SOHC has 6 flywheel bolts, DOHC has 8.
Cranks:
Measure the strokes
B16A/B - 70.4mm
B17A - 81.7mm
B18A/B - 89mm
B18C1/C5 - 87.2mm
The only problem you'll run into is the GSR/ITR cranks, I don't know how to tell the difference, maybe someone else can shed some light cuz they look the same to me. As far as the Civic Type-R motor, i've never seen a CTR crank before and I doubt you'll come acrossed one cuz they aren't as common as other motors.
Cranks:
Measure the strokes
B16A/B - 70.4mm
B17A - 81.7mm
B18A/B - 89mm
B18C1/C5 - 87.2mm
92integraVTECgsr
Apr 30, 2006 10:38 AM
