Post Wheel Size and Amount of Lowering
Old May 1, 2002 | 01:33 PM
Shingoblade-GSR's Avatar
Default Post Wheel Size and Amount of Lowering
Hi all,
I drive a black 1999 gsr. I plan to lower my car this summer on either the stock 15" "blades" or some 17" "lightweight" wheels. I was wondering how much I should lower it (1.25 - 1.75 inches) with either set of wheels. I would prefer to maintain a decent ride height (avoid scratching OEM kit) but at the same time get rid of most of the wheelgap. Coilovers are a possibility. Thanks!
Shingoblade
ps. I apologize for clogging the forum with this n00b question. I did a search but didn't really come up with what I needed.
Old May 1, 2002 | 02:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Post Wheel Size and Amount of Lowering (Shingoblade-GSR)
See sig for suspension, rear shocks on lower perch, close to 2" drop all around (estimate).
Old May 1, 2002 | 02:54 PM
SonicBlueTeg's Avatar
here we go i forgot to add the /images tag.. duuuh..
its a 2.25" drop(lowering springs only)..
stockies.. &
rear and front gap
16"rims 45 series tires.
[Modified by SonicBlueTeg, 5:28 PM 5/1/2002]
Old May 1, 2002 | 03:56 PM
Adampops's Avatar
Default Re: Post Wheel Size and Amount of Lowering (SonicBlueTeg)
I am having a few questions about suspension also. I would like to really get rid of the fat wheel well gap i have now, and gain some nice controll while at it. I have already made my decesion on Koni Yellows, but i dont know if i wanna go with GC Coilovers made for the Koni shock, or just the Ebach Sportlines. I would much rather have the GC's for adjustability purposes, but i dont wanna have different ride heights (it would be hard for each side to be the exact same the its opposite side) by the way, how do you tell how much to lower each side, do you just eyeball it???
Old May 1, 2002 | 04:30 PM
Default Re: Post Wheel Size and Amount of Lowering (Adampops)
i do believe that adjustable ride height shocks have threads like a screw would(so you just have to remember how many times you turned it and apply the same amount of turns to the opposite side)..
Old May 1, 2002 | 04:37 PM
sutrusu's Avatar
count the number of times the ground control logo faces you.
im lowered with 1/2 finger gap all around on ground control sleeves and kyb agx with 17" subzeros
Old May 1, 2002 | 05:07 PM
Just2Fast's Avatar
Default Re: Post Wheel Size and Amount of Lowering (sutrusu)
How is the Ride with the ground controls and Agx's?
Old May 1, 2002 | 05:23 PM
ridnmyhonda's Avatar
nice car!!! 17's a little to big for my taste but hey not my car...i love what you did with the rear tails did you dol that yourself or what??
Old May 1, 2002 | 05:55 PM
sutrusu's Avatar
Default Re: Post Wheel Size and Amount of Lowering (ridnmyhonda)
ride with GC and KYB dependso nthe setting. it can be adjusted from "hey this is a little stiffer than stock" to "FXCK! i broke my tailbone on that 1 inch crack in the road!"
but i used VHT niteshades tinting spray paint.... the light shines through like nothing was on them... here are more pics
Old May 1, 2002 | 05:59 PM
sutrusu's Avatar
heres a shot from when i wasnt as low
Old May 1, 2002 | 08:19 PM
JCushing's Avatar
ok i have stock gs mesh 15's with ground controls loweres apx ~1.75 ". i have just under a 1 finger gap front and a solid 1 finger rear. i scrape my oem front lip only on bad bad roads. i have pics on my page. im too lazy to post them now.
Old May 1, 2002 | 09:16 PM
vti-R's Avatar
sutrusu, my car looks like urs except that i have different 17" rims..
Old May 1, 2002 | 10:31 PM
vteg's Avatar
New User
I have 17's and sportlines with 1.7 lowering. Ride is good. A bit rough an noisy at times because of the 40 series tires though.
Old May 2, 2002 | 12:54 AM
B18C1 for fun's Avatar
Default Re: Post Wheel Size and Amount of Lowering (vteg)
Here are some pics of my slammed integra. 18" Racing Hart C5 EVO's, lowered with koni yellows and skunk2 coilovers.
Old May 2, 2002 | 03:43 AM
neo1z's Avatar
Default Re: Post Wheel Size and Amount of Lowering (ForceFedGSR)
that is very very low. damn!
Old May 2, 2002 | 05:34 AM
jamal-188's Avatar
Default Re: Post Wheel Size and Amount of Lowering (neo1z)
18's lowered about 2 inches w/ Koni coilvers. had to grind inside of fenders so they wouldnt' rub.
Old May 2, 2002 | 06:18 PM
Default Re: Post Wheel Size and Amount of Lowering (jamal-188)
Wow those are some pretty nice rides. I think anything more than 2 inches + 17"s is a bit too much for me. 1.25-1.5 inch drop should be good enough. Plus the OEM kit should make the car seem lower to the ground. Thanks for the input everyone.
Shingo
Old May 2, 2002 | 06:50 PM
Slider's Avatar
sutrusu: what tire size is that?
Old May 2, 2002 | 07:11 PM
Integra97Zeke's Avatar
Default Re: Post Wheel Size and Amount of Lowering (Slider)
17's dropped her about 2 inches
Old May 2, 2002 | 07:27 PM
ghettols's Avatar
sonicblueteg....
do you wanna sell those betas???
forcefedgsr...
damn...that ish is crazy
Old May 2, 2002 | 07:30 PM
rubens's Avatar
I would strongly reccomend the Eibach Pro-Kit/KYB AGX's on sale right now at groupbuycenter.com courtesy of *** import.. a pretty decent drop IMO- not slammed, but a nice drop (1.5 all around)
Tye123
Aug 2, 2017 11:17 PM
Probot
Honda Civic (2006 - 2015)
16
Sep 29, 2012 08:57 AM
20_sec.hatch
Acura TL, RL & ZDX
Sep 11, 2008 12:25 PM
ES1Racer
Honda Civic (2001 - 2005)
May 15, 2008 10:50 AM
tpot90
Feb 27, 2008 01:33 AM
