can you identify this volvo-turbo
Old Sep 28, 2006 | 07:25 AM
wolve's Avatar
Default can you identify this turbo
do you know what kind this is and what it's comparable to?
got it for free , but don't have a clue what it's capable of
hi-res copy-paste: http://www.mijnalbum.nl/GroteFoto=7AFVIYXQ
hi-res copy-paste: http://www.mijnalbum.nl/GroteFoto=KBXJCYIL
hi-res copy-paste: http://www.mijnalbum.nl/GroteFoto=7M6PX3HJ
pretty nice for my phone-pics huh love my phone
anyone has a clue? the aprox power it supports? decent spooltime on a D15b7?
Modified by wolve at 1:47 PM 9/28/2006
Old Sep 28, 2006 | 08:19 AM
JoePSI's Avatar
Default Re: can you identify this volvo-turbo (wolve)
Looks like a new one I would go through their recent cars and see what turbo has that specifications and measurements and compare.. Sorry I'm not more help but free bump for you.
Old Sep 28, 2006 | 12:47 PM
wolve's Avatar
Default Re: can you identify this volvo-turbo (JoePSI)
bump
Old Oct 3, 2006 | 01:37 AM
wolve's Avatar
i got myself some drawings from mitsu, it's not excactly the same (outlet compressor housing has a bent) but it says : TD04L-12T
can anyone elaborate on power possible with d15b7 and spooltime?
Old Oct 3, 2006 | 05:18 AM
redzcstandardhatch's Avatar
something different
seems kinda big for a d, but i'd rock it! haha
Old Oct 3, 2006 | 05:24 AM
wolve's Avatar
Default Re: (redzcstandardhatch)
anyone know if it's BB? it turns as soon as i blow in the turbine inlet. it's quite a big inlet so i can't put my mouth around it.... so i just blow in it and it spins,
wait i make a video
Edit: link is http://videos.streetfire.net/v...6.htm
Modified by wolve at 6:41 AM 10/3/2006
Old Oct 3, 2006 | 05:37 AM
BoostedEG6's Avatar
Default Re: (wolve)
looks BB to me.... has oil feed and drain plus water inlet and outlets from the looks of it
Old Oct 3, 2006 | 05:43 AM
wolve's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">looks BB to me.... has oil feed and drain plus water inlet and outlets from the looks of it </TD></TR></TABLE>
your totally right, i did not knew that they where pointers to a bb-turbo
Old Oct 3, 2006 | 06:30 AM
splitime's Avatar
Large percentage of typical turbos have dual center sections. That definitly isn't a telltale BB sign. Very doubtful that a volvo will come from factory with a BB turbo.
Old Oct 3, 2006 | 07:28 AM
TTT's Avatar
TTT
I can't tell exactly what turbo it is, but if it is the biggest Mitsu turbo that goes on a volvo then it can support 330hp and that is it. Most of those turbos could only do around 250hp.
Old Oct 9, 2006 | 03:17 AM
wolve's Avatar
Default Re: can you identify this turbo (wolve)
found a thread on the td04l-12t
https://honda-tech.com/zerothread?id=844229
hopin to see just over 200whp, rods aren't gonna hold anymore either.
volvo S40 T5's stock numbers are
5 cilinders in a row, 20v
2521cc 83,0 x 93,2 mm
9,0:1
220 hp @ 5000rpm and 320 nm @ 1500rpm
this all is multipoint, intercooled and with cat
very nice prospect for me
what do you think of the drivability on a d15b7?
Old Oct 9, 2006 | 06:56 AM
turboteener's Avatar
Banned
Looks kinda like a T3 50trim. Although the T3 has garret tags on it.
Old Oct 9, 2006 | 08:39 AM
AbitAvenger's Avatar
should spool fast on a single cam, i bet you could make 200hp with headstuds and 10-12lbs of boost
uareguy
Other Make Vehicles
Dec 20, 2008 07:01 AM
ay-s-2k
Apr 19, 2008 12:12 AM
jason DB8
Apr 18, 2005 04:54 PM
90hbvtec
Jul 17, 2004 10:13 AM
