What size relay do I need? (wiring diagram inside)
Old Sep 28, 2006 | 02:53 AM
raceACCORDingly's Avatar
Default What size relay do I need? (wiring diagram inside)
If I were to wire up an ignition kill switch w/ relay on the Black/White line between the ignition switch and the under dash fuse box, what size relay would I need?
The 7.5A fuse between the ignition switch (Black/White) and the main relay (Blue/Red) is throwing me off. This Black/White line is pretty thick like 12 guage or so, but is it only drawing < 7.5A?
Old Sep 28, 2006 | 09:18 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: What size relay do I need? (raceACCORDingly)
Just a standered dc12v 30/40a relay. If you are local I'll give you one for free. I see so-cal in you name.
I like suspended hatch I deal on a battery switch with a small fuse. I trying this this weekend as a layer. I got you on a six pack Mr hatch. But yea make sure you do something else because there are many other ways to start the car. I not going to say on a plubic board but take a look at suspended hatch write up on his site. The info there is great and everybody needs to read it. Pmed
Old Sep 28, 2006 | 05:54 PM
so a regular 30/40a spdt relay will work?
the ignition switch line is like 12guage and the wires on teh socket of the relay are only like 16 guage...
Old Sep 28, 2006 | 06:14 PM
Default Re: (raceACCORDingly)
yes it will work
Old Sep 28, 2006 | 07:46 PM
fcm's Avatar
fcm
Old Fart
If you look close you will see the 7.5A fuse is not on the starter solenoid circuit, that wire, ["12ga or so" starter lead, black/white] is protected by the 50A fuse in under hood fuse box, although it does not take anywhere near 50A to trigger the starter solenoid, a standard SPDT 30A/40A relay will work fine. 94
Old Sep 28, 2006 | 07:51 PM
Thanks.
stinkypinky1011
21
Nov 11, 2013 11:18 PM
jc95148
Audio / Security / Video
Dec 16, 2012 02:57 PM
gutted-dx
18
Jun 21, 2005 03:34 PM
mongoliandonuts
Jun 14, 2004 09:22 AM
daver
Apr 18, 2004 01:53 PM
