Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
questtion about my cold air inttake on 05 civic lx, need help.
Old Sep 27, 2006 | 07:01 PM
zyprexa's Avatar
Default questtion about my cold air inttake on 05 civic lx, need help.
I have a injen cold air inttake installed in my 05 civic lx. However the filter is positioned right behind the lower end of my radiator. I'm wondering if there is suffecient air getting in with it being behind my radiator. Isn't this hot air getting into my engine instead of cold air?
Old Sep 27, 2006 | 07:50 PM
toyomatt84's Avatar
Sanji
Well, the air temperature would be cooler if you were able to pull from a fresh air source, but it's not like you'd see a performance gain either way. So, I guess it really doesn't matter if it's behind your radiator or not, is what I'm trying to say.
Old Sep 28, 2006 | 11:53 AM
zyprexa's Avatar
Default Re: (toyomatt84)
So should I remove the intake and install the stock intake? I hear that cooler air passes through your radiattor that anywhere else on your car. I just dont want to ruin my engine witth a hot air fuel mixtture.
Old Sep 28, 2006 | 11:59 AM
toyomatt84's Avatar
Sanji
Default Re: (zyprexa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyprexa &raquo;</TD></TR><TR><TD CLASS="quote">So should I remove the intake and install the stock intake? I hear that cooler air passes through your radiattor that anywhere else on your car. I just dont want to ruin my engine witth a hot air fuel mixtture.</TD></TR></TABLE>
I doubt you're causing undue damage to your car with the setup you have right now. I'd say it's up to you. If you like the extra whoosh noise from the more open-air intake, then keep it on. If you prefer a more quiet appeal, then swap out for the stock setup. Either way, you're not really causing tons of extra damage to your engine.
Old Sep 28, 2006 | 12:16 PM
zyprexa's Avatar
thnx matt, I'll keep it on. I paid 250 bucks for itt so I mightt as well right?
Old Sep 28, 2006 | 12:19 PM
TN90accord's Avatar
plus it looks cool right? I like my K&N intake...I just hate my D17...except when it's time to fill up.
Greyhead
Honda CR-V & Element
Mar 18, 2014 05:35 PM
'93ludeboy
Dec 9, 2012 02:17 PM
threenuts84
Aug 28, 2007 05:56 PM
the king.
Mar 29, 2007 07:35 PM
crooked muffler
May 21, 2003 02:57 PM
