changing brake pads?
Old May 1, 2002 | 12:24 PM
clean's Avatar
New User
Default changing brake pads?
guys my front brake pads are gone. i started hearing the metal scraping noise last week but didnt want to deal w/ it and now i have to. i looked at them and there is no meant left. should i try and change them on my own or just pay the shop to do it. oh yeah and should i just stick w/ oem pads? thanks
Old May 1, 2002 | 12:59 PM
brcivic411's Avatar
Default Re: changing brake pads? (clean)
change pads isn't that big of a deal but a shop will probably charge you like it is!
a helms manual shows you everything you need to know
hopefully you didn't screw anything up by waiting so long...
Old May 1, 2002 | 01:44 PM
hybridreams's Avatar
Default Re: changing brake pads? (brcivic411)
Rotors are gonna feel lovely when you brake after you're done...
Get them resurfaced
Old May 1, 2002 | 02:16 PM
Name's Avatar
You might need to get your rotors turned. If they have grooves in them take it to a brake shop and have them do the whole thing if not its fairly easy to do a brake job yourself. I would use oem parts by the way.
Old May 1, 2002 | 03:01 PM
riceboy's Avatar
Default Re: changing brake pads? (JdmTypR)
yea, get the rotors turned, and if you have a c-clamp to compress the piston, then it isnt hard to change the pads at all, and once youve got the caliper off and the pads out, you can take the rotors off and take them up to a local shop and they can resurface them for about $15-$20 a rotor.
Old May 6, 2002 | 10:58 AM
clean's Avatar
New User
Default Re: changing brake pads? (riceboy)
where do i get the pads from? how muych roughly too? thanks
Old May 6, 2002 | 01:30 PM
THE *FOB* MOB's Avatar
get them from the dealer...probably cost u roughly $40...don't go to pep boys or autozone
Old May 6, 2002 | 09:43 PM
MurphDog74's Avatar
it takes about 10 mins to get the caliper off and just pop out the old pads and put in the new ones. Not counting the time to jack it up and take off the tire.
Old May 7, 2002 | 07:00 PM
clean's Avatar
New User
Default Re: changing brake pads? (MurphDog74)
**** i got the $16.00 ones from nappa!!!! o well i also dont have sqeuk spray eithtr. wish my dumb *** luck.
p.s. bring me anothe six pack please!!!! sam adams summer plaese
Old May 7, 2002 | 11:29 PM
stockegsix's Avatar
i change my brakes for the first time, the shop wants $125 for it so i decided to do it myself. i check my rotors and they were fine.
$30 bucks for brake pads, $11 bucks for shims and $2.50 for anti-squeal stuff.
it took me about an hour and i had a haynes manual. its not that hard. peace
97 civic dx coupe(all silver)
95 jdm b16a(obd1-obd2 skunk2 harness)
gsr tranny
p28ecu w/ skunk2 chip
AEM CAI
Greddy Evo
R1 coilovers w/ KYB gr-2
gsr rear disk convertion
si wheels
Old May 8, 2002 | 09:57 AM
clean's Avatar
New User
Default Re: changing brake pads? (silversleeper)
well i used the old shim, and no anti squel ****. but now i think i gotta bleed my brakes and i dont have the stuff to do it? anyone have an suggestions, it did take bout 30 min. too
Old May 8, 2002 | 10:16 AM
Gennady's Avatar
New User
More like 1 minute if the bolts come off righ away, 30 minutes if they dont.
Changing pads is so simple.
1. Remove lower caliper bolt and flip caliper up.
2. Pull out old pads and replace with new pads.
3. Compress piston back in with a C-clamp.
4. Pull down caliper and replace lower caliper bolt.
Simple as that. Any monkey with a wrench can do it.
Old May 9, 2002 | 03:49 AM
VWkila's Avatar
Default Re: changing brake pads? (Wont be beat)
hey, silversleeper, where did you buy your shims?
I need a set of break shims for 3rd gen Integra.
Shims alone are on national back-order and I've checked with Pepboys and Autozone. Neither places carrys them.
At the Acura dealer, they have the break pads in stock, but I already bought a set of AEM brake pads.
TypeRod
Mar 25, 2012 03:47 PM
NXSpoon
May 16, 2007 01:25 PM
ndogg810
Honda Civic (2001 - 2005)
Jan 6, 2007 05:23 PM
faSHOwidIT
Apr 18, 2005 02:06 AM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
