hit boost then it sputters?
Old Sep 27, 2006 | 06:23 PM
99delsol's Avatar
Default hit boost then it sputters?
is it my bov or is it coming from my resonator,i dont hear the pssshh sound from my bov just the sputter,i know alot of people must have come across this so if you had this problem let me know the solution thanks for all positive input
Old Sep 28, 2006 | 02:13 AM
blackeg's Avatar
Default Re: hit boost then it sputters? (99delsol)
id bet your running lean, if right when you hit boost it starts to b uck and break up
Old Sep 28, 2006 | 08:04 AM
99delsol's Avatar
what do i do this fix this problem.anyone else?
Old Sep 28, 2006 | 08:10 AM
1badda's Avatar
same probelm with me it seems
Old Sep 28, 2006 | 09:01 AM
99delsol's Avatar
solution?????????/
Old Sep 28, 2006 | 09:54 AM
petergriffen's Avatar
Default Re: (99delsol)
mine made that sound like instead of the blow off valve sound it would like sputtering sound. make sure u have vaccume lines on right the bolt on the top of my greddy type-s fell off and was causing as vaccume leak then i fixed it and it works again.
Old Sep 28, 2006 | 11:04 AM
HNLV's Avatar
maybe ur blowing out the spark
Old Sep 28, 2006 | 11:20 AM
1badda's Avatar
how the expletive would u blow out spark
Old Sep 28, 2006 | 11:34 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (streetaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetaccord &raquo;</TD></TR><TR><TD CLASS="quote">how the expletive would u blow out spark</TD></TR></TABLE>
with the gap too high and the plugs too hot, the extra combustion pressure can "blow out the spark"
it is a figurative term for the plug not firing.
how much power you making, what plugs, and what ignition system?
first off where are your air fuels, and are you running management? if so what?
Old Sep 28, 2006 | 11:37 AM
drintegra's Avatar
check the bolt on the bov. make sure the vacuum lines are correct. i belive the top fitting needs the line on the type s
Old Sep 28, 2006 | 11:46 AM
1badda's Avatar
i know the top fitting on tial style wastegate is not slealing right.could that be the probelm
Old Sep 28, 2006 | 02:19 PM
99delsol's Avatar
i have a generic greddy type rs bov,i just went to go loosen/soft ,and still same thing,i have my bov connected to a vac line with another t for my boost guage ,would that be why,any ideas let me know thanks
Old Sep 28, 2006 | 08:06 PM
99delsol's Avatar
any answers out there?
Old Sep 28, 2006 | 08:08 PM
Mr. Badwrench
are you breaking up or are you having compressor surge? there is a big frikin difference......we are chasing one problem, and i think you are experiencing another.
Old Sep 29, 2006 | 07:29 AM
1badda's Avatar
For me it seem like it breaking up
Old Sep 29, 2006 | 07:39 AM
drintegra's Avatar
When you say breaking up is the car losing power, does it shutter and feel like you hit the rev limiter, does it feel like it is not boosting and you hearing a sound like pressurized air when this occurs?
Describe the problem with more detail, it could be distributor(spark related), fuel, or loose lines. **** it could even be that you need motor mounts and when you boost the motor moves up causing the downpipe to disconnect from the wrest of the exhaust. Depends on alot of things
Old Sep 29, 2006 | 07:48 AM
Kris's Avatar
Default Re: (drintegra)
Tighten the gap on your spark plugs a little bit and see if that helps, if it doesn't, come back on here and say so........
Old Sep 29, 2006 | 07:54 AM
darkdayz's Avatar
Default Re: (Kris)
what engine management
Old Sep 29, 2006 | 08:05 AM
turbotime's Avatar
spark blowout i agree
Old Sep 29, 2006 | 12:12 PM
1badda's Avatar
Were using crome pro. turbo kicks in i can feel it but it just after 5 grand it just struggling to get to redline. feel as if no power at all.
Old Sep 29, 2006 | 01:29 PM
vxhatched's Avatar
Could be vacuum leak, boost pipe leak, BOV sticking, ive seen that happen
Old Sep 29, 2006 | 02:12 PM
Schister66's Avatar
Man U FTW
plugs....that would be my first guess. That happened to me when i first boosted my GSR. I blew the spark out. Once i got NGK BKR7E's the problem went away
Old Sep 29, 2006 | 02:18 PM
TIGboy's Avatar
whats ur setup?!
Old Sep 29, 2006 | 02:42 PM
99delsol's Avatar
my setup is a greddy turbo kit,16g,stock b16,310 injectors,greddy piggyback
Old Sep 29, 2006 | 02:43 PM
99delsol's Avatar
how much should i gap it?
