head bolt torque specs
Old Sep 27, 2006 | 06:01 PM
GsrIntegra789's Avatar
Default head bolt torque specs
does anyone have the specs on how to torque down a gsr head? also the cams thanx
Old Sep 27, 2006 | 06:05 PM
Dartanian's Avatar
Default Re: head bolt torque specs (GsrIntegra789)
Head bolts are 60 ft/lbs. 12mm cam bolts are 20 ft/lbs and 10mm cam bolts are 7.2ft/lbs.
Modified by Dartanian at 7:17 PM 9/27/2006
Old Sep 27, 2006 | 06:12 PM
Default Re: head bolt torque specs (Dartanian)
thanx do u know the pattern to tighten them ?
Old Sep 27, 2006 | 06:17 PM
Dartanian's Avatar
7 3 1 5 9
8 4 2 6 10
Same with the cam holder bolts except keep the same pattern when tightening the 10mm bolts last. Do intake and exhaust cam holders separately.
I forgot to add that the head bolts should be torqued in two steps: 22 ft/lbs in that pattern and then 60 ft/lbs in that pattern.
Old Sep 28, 2006 | 04:59 AM
thanx alot man
Old Sep 28, 2006 | 07:26 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Go to hondahookup.com and register, and download a manual. Just to be sure.
I did that and it's great, great source of info, get it man.
polishedturd
May 29, 2009 05:41 AM
NSfit
Aug 24, 2006 04:36 PM
Tofurky
Feb 26, 2005 05:31 PM
tuan...
Nov 20, 2004 01:37 PM
b20b
Mar 4, 2002 03:28 AM
