No Cold Start
I know this topic is one thats been extensively covered, but none of the problems others had really fit mine.
The car starts great when its warm out, but when i go to start it in the morning it doesnt start. I have fuel, but no spark. I dont really understand how i can get no spark in the morning but have spark when its warm out...oh yea and the car cranks fine suggesting good battery(i think) and a good starter. The battery is fairly new and freshly charged, so what can the problem be?
Any help appreciated.
no spark, i dont have a factory ignitor as msd replaces that. It is getting fuel, just no spark, and for some reason this only occurs in the morning when its cold out.
sounds like a main relay...
https://honda-tech.com/zerothread?id=1032246 - how to test your main relay
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 »</TD></TR><TR><TD CLASS="quote">sounds like a main relay...
good luck</TD></TR></TABLE>
Hey already stated that he has fuel but no spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin »</TD></TR><TR><TD CLASS="quote">Hey already stated that he has fuel but no spark.</TD></TR></TABLE>
Actually, he said that he did have spark when it was warm outside, and no spark in the morning when it was cold, so again I say check the main relay....good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpt Ben »</TD></TR><TR><TD CLASS="quote">the car started this morning, but only very briefly, it started, then almost immediately died and wouldnt start again.</TD></TR></TABLE>
so if the car started, you must have had spark....are you absolutely sure you had fuel? now it sounds like fuel pump, or fuel filter....this might sound dumb, but do you have enough gas in the car? you might also check for vapor lock..........just an idea.......I know one of the main techs at Honda and he removed his MSD and went back to stock for some reason....good luck
tank is full, i can hear the pump priming. as for vapor lock i cant see how it could get into the lines, as i havent done anything fuel line related in a while. Ill replace the fuel filter and see what happens. MSD is coming out too, just as soon as i find another wiring harness
davidzhou4893
10
Mar 18, 2014 08:53 AM
dub204
Aug 20, 2006 09:14 AM
