assembling SRP pistons onto Eagle rods
Old Sep 27, 2006 | 01:10 PM
d16dcoe45's Avatar
Default assembling SRP pistons onto Eagle rods
My 75.5mm SRP pistons came in today for my a6 (re) build. Last week I took off the old 79mm JE pistons that were attached to the Eagle rods (which I am reusing). The problem is, I paid no attention to how the rods were situated on the pistons. I am wondering which side should the bearing tang (in the rods) point to? On the stock a6 piston/rod I have in front of me, the bearing tang is on the exhaust side--is that how it should be with these Eagles/SRPs? I hope I am making this clear enough--I just don't want to assemble these things and then find out that the tang is pointing the wrong way--those Spiro-Locks are a bitch to take off!!!
Old Sep 27, 2006 | 01:34 PM
SIXTY's Avatar
Default Re: assembling SRP pistons onto Eagle rods (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">My 75.5mm SRP pistons came in today for my a6 (re) build. Last week I took off the old 79mm JE pistons that were attached to the Eagle rods (which I am reusing). The problem is, I paid no attention to how the rods were situated on the pistons. I am wondering which side should the bearing tang (in the rods) point to? On the stock a6 piston/rod I have in front of me, the bearing tang is on the exhaust side--is that how it should be with these Eagles/SRPs? I hope I am making this clear enough--I just don't want to assemble these things and then find out that the tang is pointing the wrong way--those Spiro-Locks are a bitch to take off!!!</TD></TR></TABLE>
i know, i just stabbed my self in the hand
Old Sep 27, 2006 | 03:51 PM
d16dcoe45's Avatar
Default Re: assembling SRP pistons onto Eagle rods (SIXTY)
Am I putting too much thought into this? I have searched and it seems some of the pistons are mounted with the intake reliefs on the bearing tang side of the rod, and some with the exhaust reliefs on the bearing tang side of the rod....
Old Sep 27, 2006 | 04:43 PM
lohatch's Avatar
tangs go on the exhaust side
Old Sep 27, 2006 | 05:15 PM
d16dcoe45's Avatar
Default Re: assembling SRP pistons onto Eagle rods (lohatch)
thanks
Vagitarian
Sep 14, 2012 02:14 PM
young geezer
Oct 13, 2010 01:16 PM
SiR99
Sep 1, 2006 09:17 PM
