cel code 43
Old Sep 27, 2006 | 12:11 PM
92GSR HB's Avatar
Default cel code 43
My car recently has been throwing Cel 1 and 43. im more concerned with the 43 than anything. im going to pull the injectors and soak them in cleaner to see if that might be the problem. btw my car has a new fuel filter. anybody got other suggestion to what might be causing this?
Old Sep 27, 2006 | 12:44 PM
slomofo's Avatar
GDD Member
Do you have any vaccuum leaks? Is your FPR adjustable?
Old Sep 27, 2006 | 12:46 PM
civickiller's Avatar
Default Re: cel code 43 (92GSR HB)
sometimes a bad o2 will cause a code 43, i believe
Old Sep 27, 2006 | 12:49 PM
92GSR HB's Avatar
it is throwing a code 1 which is O2, but that sensor is relatively new. No i just have a FP Gauge thats it. My car sometime tends to start then die like its not gettin gas, but usually starts the next try or so.
Old Sep 27, 2006 | 01:54 PM
slomofo's Avatar
GDD Member
Test the fuel pressure, it could be your FPR or maybe your pump.
Old Sep 27, 2006 | 07:02 PM
92GSR HB's Avatar
my fp gauge has been reading different numbers lately, usually a 5-10 psi difference at idle. im cleanin the injectors tomarrow, if continues ill look into investing into a wally pump. i wished i had a wideband grr
Old Oct 5, 2006 | 11:48 PM
imjustakid's Avatar
check the voltage on the connectors sometime they don't spray enough fuel due to lack of voltage
nate10498
Apr 10, 2006 08:54 AM
PhilStubbs
Jan 22, 2005 11:20 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
OBDI JEDI
May 7, 2003 05:06 PM
