How do I install the tps sensor?
Put it on with NORMAL phillips screws, in case you need to take it off again.
Don't tighten it all the way down.
Get out a multimeter and check the voltage. with KEY On, throttle closed it should be .5 volts, with throttle OPEN it should be 4.5-5 volts.
Once your in those prarameters, tighten screws, done......
civic_tuned
15
Aug 29, 2005 11:31 AM
rasta420
17
Apr 11, 2003 02:24 PM
