How do I install the tps sensor?
Ok, so I know my car needs a new tps sensor, but how do I get the old one off, and put the new back on? Any help will be greatly appreciated.
Re: How do I install the tps sensor? (avsrule414)
get a screw driver and a hammer and hit it sideways on the little lump thin that looks like a (cant remember the name of those little things)
Re: How do I install the tps sensor? (EGwhat!!!)
Put it on with NORMAL phillips screws, in case you need to take it off again.
Don't tighten it all the way down.
Get out a multimeter and check the voltage. with KEY On, throttle closed it should be .5 volts, with throttle OPEN it should be 4.5-5 volts.
Once your in those prarameters, tighten screws, done......
civic_tuned
15
08-29-2005 11:31 AM
rasta420
17
04-11-2003 02:24 PM
