Hub Swap
I want to go witha 5 lug conversion without swapping the whole spindle and rear trialing arms. i have the 5 lug hubs from Type R and would like to see if these will fit my stock integra spindles and trailing arms.
yeah take caliper rotor in the center there is a cap if you dont have the propper tool to get it off you can use a small screwdriver and hammer then there is a 32mm bolt take that off and good to go make sure you put some grease on it and do reverse orfer btw you dont have to swap out brake lines in the rear
are the stock integra rear calipers the same as ITR? can i use back the same ones i have cause i just bought new rotors and pads. do you happen to know the part number or where would i look under the Acura parts site?
http://www.acuraautomotivepart...gry5=
Sypher
Apr 6, 2008 12:51 AM
Lissav
29
Mar 17, 2006 11:07 AM
