low beams don't work ...???
okay this is totally mind wrecking for me .. but maybe 'cuz i stress easy.
I have 2001 ex and my low beams just stopped working. The high beams work fine but the low beams don't work. I tried swapping light bulbs but that doesn't seem the problem as the new bulbs won't work either. Can anyone suggest where the problem might be? and how much am i looking at to get fixed??
Thanks
Thanks
maybe its the wrong bulbs, they are double filament, meaning they work for both, low and high beams.
did they work before, with these same bulbs? if so, try some other bulbs. if not, check to see if there's any loose wiring on the socket...
The relays go out once in a while
Look into the fues box inside the engine bay.
Is on the left side (passenger) just below the strut tower.
Open the lid ,on the bottom of the lid it tell you whitch relay (a square black box 1" wide) is the one for the low beams.
There should be two one for low and one for high.
All relays are all the same type, to test, just swap one of the other ones turn low beam lighs on, if that's he problem just buy another.
Dub C
May 28, 2011 01:25 PM
GraphiteMW
Jun 26, 2008 04:12 PM
Cashieboi
12
Mar 1, 2008 08:44 PM
EH2_pReStO
Nov 21, 2003 02:28 PM
