desperate. . . need smog help in san diego/so cal. please, please please
Old Sep 27, 2006 | 08:47 AM
jay_cue's Avatar
Default desperate. . . need smog help in san diego/so cal. please, please please
i have a 92 hatch with an obd1 gsr motor.
i decided i wanted to smog the vehicle the right way, and try to bar the car instead paying for a smog hook up. but it looks as though trying to be honest has bitten me hard in the ***. i passed my visual, but failed the emmissions horribly. but now i'm stuck. i've been calling everywhere, and no one will even look at the car because its not certified. but i can't get certified until i bring down the emmissions.
so i'm here on h-t to ask for some help. if anyone can do a diagnosis to help bring down my emmission, or know where i can bring my car to so i can get it bar'd.
i'm not looking for a smog hook up. its not even an option at this point since i've failed at the ref station. but i'm trying to get this done right. i'm willing to pay to get it fixed correctly.
so any help would be greatly appreciated.
please please please.
Old Sep 27, 2006 | 08:58 AM
Mike Ockhurts's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (whal3_p3nis)
your fucked either way, its just a matter of if you want it with the KY or RAW
juevi (old)'s Avatar
Independent Auto Repair and Maintenence 619-276-7672
Tell them a IATN member reffered you. If they don't handle this kind of thing they will refer you to someone who will.
Old Sep 27, 2006 | 09:01 AM
jay_cue's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (juevi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juevi &raquo;</TD></TR><TR><TD CLASS="quote">Independent Auto Repair and Maintenence 619-276-7672
Tell them a IATN member reffered you. If they don't handle this kind of thing they will refer you to someone who will.</TD></TR></TABLE>
thanks. calling right now.
Old Sep 27, 2006 | 09:02 AM
itsjdmbradyo!'s Avatar
well first off is your motor stock? and have you removed any SMOG equipment from the motor? alot of the tims when a car fails simply adding a new catalytic converter will get you to pass, also after market intakes make your numbers rise alot too, but like i said what mods are done to your motor?
Old Sep 27, 2006 | 09:07 AM
jay_cue's Avatar
tried calling them. but they dont do any of that work. the people they referred me to was a test only thanks though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! &raquo;</TD></TR><TR><TD CLASS="quote">well first off is your motor stock? and have you removed any SMOG equipment from the motor? alot of the tims when a car fails simply adding a new catalytic converter will get you to pass, also after market intakes make your numbers rise alot too, but like i said what mods are done to your motor?</TD></TR></TABLE>
i haven't taken any smog stuff off. i passed the visual. i have dc hearders, aem intake. i passed the visual with that stuff since theyre listed as carb exempt. i changed the cat, it brought down the numbers but still failed.
Old Sep 27, 2006 | 09:10 AM
unltdacc12's Avatar
Post your numbers. What part of the sniffer test did you fail?
jay_cue's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (unltdacc12)
all three. let me go find mine sheet.
Old Sep 27, 2006 | 09:20 AM
jay_cue's Avatar
first smog
15 mph 1918 rpms
HC: actual: 173; max: 121
CO: actual: .80; max: .76
NO: actual: 2790; max 807
25 mph 2241 rpms
HC: actual: 148; max: 96
CO: actual: 1.03; max: .65
NO: actual: 1512; max 746
second smog
15 mph 1889 rpms
HC: actual: 200; max: 121
CO: actual: .93; max: .76
NO: actual: 1997; max 807
25 mph 2258 rpms
HC: actual: 189; max: 96
CO: actual: 2.04; max: .65
NO: actual: 411; max 746
Old Sep 27, 2006 | 09:23 AM
Those punks, try this one. Z-Whizz Complete Auto Repair & Sales 858 492-5139
Or you can try this guy, he specializes in Honda's but not sure how far he is from you. Peterson's Automotive 760-738-4800. He's in Escondido, CA
Old Sep 27, 2006 | 09:25 AM
So the only mods are a Header and Intake?
Old Sep 27, 2006 | 09:29 AM
unltdacc12's Avatar
Try running sea foam or top engine cleaner. those should bring down your HC and CO levels a bit. as for NOx, whats your timing set to? try retarding your timing to whatever the minimum is.
Old Sep 27, 2006 | 10:15 AM
yea judging by those numbers something way off, id suggest getting a stock exhaust and intake, doing a complete tune up and running sea foam then chagning your oil. because those are gross polluter numbers and means theres something wrong with your motor deffinetly get the timing checked out also(autozone can do that for you)
Old Sep 27, 2006 | 11:49 AM
jay_cue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juevi &raquo;</TD></TR><TR><TD CLASS="quote">Those punks, try this one. Z-Whizz Complete Auto Repair & Sales 858 492-5139
Or you can try this guy, he specializes in Honda's but not sure how far he is from you. Peterson's Automotive 760-738-4800. He's in Escondido, CA</TD></TR></TABLE>
tried calling them. no one wants to even look at the car since it's not the same motor as the vehicle. but it should be the same as looking at a gsr, its just the body looks different.
arrr so frustrating. starting to wish i paid the 300 some dollars just to have it smogged.
Old Sep 27, 2006 | 12:19 PM
junkyardTurbo's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (itsJDMbradyo!)
werd borrow a timing light and try retarding it the nox is ****** horrid.
Old Sep 27, 2006 | 08:22 PM
jay_cue's Avatar
Bump for any possible help from the night crew
Old Sep 27, 2006 | 09:14 PM
.Kevin.'s Avatar
search on here. Back when I had a civic and hung around the civic forum part there were a few threads on how to pass. Retard the timing as much as possible and what ecu are you using.
Old Sep 27, 2006 | 09:20 PM
jay_cue's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (Ep_Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">search on here. Back when I had a civic and hung around the civic forum part there were a few threads on how to pass. Retard the timing as much as possible and what ecu are you using.</TD></TR></TABLE>
Running a stock/unchipped p72
Old Sep 28, 2006 | 08:20 AM
jay_cue's Avatar
ble, called so many places, and no one is willing to look at the car. i'm starting to think i'm just going to bring it in and not even explain that it has another motor. but i'm thinking if they dont realize it doesnt have a civic motor, i shouldn't be bringing it to them. arrrr. no way to win this one.
Old Sep 28, 2006 | 08:55 AM
Paxil4x4's Avatar
You need to call your local smog referee to get a bar sticker.
Old Sep 28, 2006 | 09:39 AM
jay_cue's Avatar
Default Re: desperate. . . need smog help in san diego/so cal. please, please please (packthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis &raquo;</TD></TR><TR><TD CLASS="quote">You need to call your local smog referee to get a bar sticker. </TD></TR></TABLE>
uh yeah if you actual read through the thread, i have stated that i took it to a ref, and tried to get it certified. but i can't get it certified because i failed my emmissions. and that is why i created this thread, because the ref told me i need to go find a smog station to do a diagnosis and fix my emmissions then bring it back to get it certified.
Old Sep 28, 2006 | 09:45 AM
chunty kevin's Avatar
a member called h8zwest or hazwest should be able to help you
Old Sep 28, 2006 | 10:35 AM
jay_cue's Avatar
Default Re: (chunty *** kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunty *** kevin &raquo;</TD></TR><TR><TD CLASS="quote">a member called h8zwest or hazwest should be able to help you</TD></TR></TABLE>
thanks. i'll try to im him.
Old Sep 28, 2006 | 06:10 PM
jay_cue's Avatar
Default Re: (whal3_p3nis)
well looks like this is too much of a hassle. shell needs help anyway, so i've decided to just pull the motor, and donating the shell. so if anyone wants anything, let me know and i'll take it off before i let the shell go.
edit: not looking to part the motor as of yet, will try to sell the motor setup whole.
Old Sep 28, 2006 | 06:57 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whal3_p3nis &raquo;</TD></TR><TR><TD CLASS="quote">well looks like this is too much of a hassle. shell needs help anyway, so i've decided to just pull the motor, and donating the shell. so if anyone wants anything, let me know and i'll take it off before i let the shell go.
edit: not looking to part the motor as of yet, will try to sell the motor setup whole.</TD></TR></TABLE>
are you an idiot... this should take no time to fix.... I TOLD YOU TO SEARCH.... if you dont want to keep your car thats your fault but there are plenty of threads that will guide you to passing. Get off your lazy *** and you the botton on the top of the screen
