How can I lower my compression from 12:5:1 to 11:5:1???????
Old May 1, 2002 | 10:48 AM
Halo's Avatar
Default How can I lower my compression from 12:5:1 to 11:5:1???????
I currently have a crvtec setup using 85mm 11:5:1 JE pistons. At first I was planning on using my LS head, however I changed my mind and went with a 95 GSR head. Since the GSR has smaller combustion chambers my cr is 12:5:1. What size headgasket do I need to lower it to 11:5:1? Or would it be better to open the GSR combustion chambers to LS spec? I am currently using a cometic .062 headgasket but I am still pinging like crazy! I also increased my fp to 50and retarded my timing 2 degrees but the car still pings....What should I do?
Old May 1, 2002 | 11:01 AM
Rocket's Avatar
Default Re: How can I lower my compression from 12:5:1 to 11:5:1??????? (Halo)
I feel for you man. You can
-de-burr your pistons so they have dull edges
-open up the chamber sides a to match the bore. This will help lower the compression and make the chamber shape more combustion friendly.
-running tighter deck will help deter detonation but also raises compression. Using a 0.040 head gasket will help combustion dynamics.
Here is a pic of Endyn's pistons with nice dull radiused edges and a satiny finish.
[Modified by Rocket, 8:02 PM 5/1/2002]
Old May 1, 2002 | 11:08 AM
Halo's Avatar
Default Re: How can I lower my compression from 12:5:1 to 11:5:1??????? (Rocket)
the combustion chamber in the GSR head is 40 and the LS is 42?? Is that correct? So if I open the combustion chambers to 42, then with the stock headgasket wouldn't my cr be 11:5:1? This pistons were designed to give a 11:5:1 with the LS head. Will opening up the GSR combustion chambers also increase HP output as well? Much thanks for the info, I am getting nervous about detonating, whatever I do, I need to do it ASAP
Old May 1, 2002 | 11:12 AM
Rocket's Avatar
I am not sure if you can get 2cc's by opening up the sides but it should help a whole lot.
Yeah, detonation is for shitty old Toyotas (clak, clak, clak, clak, ) but not for high performance Honda's.
Old May 1, 2002 | 12:03 PM
MrFatBooty's Avatar
LS combustion chambers are 45cc, GSR are 41.6cc.
Do you know what your piston dome displacement is? For Arias 11.5:1 LS pistons it's 6.1cc, but they don't have any B20 applications listed on their site so I don't know the spec. I'll just assume it's the same.
So, according to http://www.c-speedracing.com/howto/c.../compcalc.html your CR is 11.18:1.
[edit] That's with your headgasket figured into the mix. With an OEM headgasket you'd be at 12.26:1.
[edit again] OEM headgasket is 0.029" thick.
[edit yet again] I'm stupid, I have no clue why I thought you said Arias pistons.
[Modified by MrFatBooty, 9:04 PM 5/1/2002]
[Modified by MrFatBooty, 9:05 PM 5/1/2002]
[Modified by MrFatBooty, 9:06 PM 5/1/2002]
Old May 1, 2002 | 12:09 PM
MrFatBooty's Avatar
Default Re: How can I lower my compression from 12:5:1 to 11:5:1??????? (MrFatBooty)
So yeah, if you know the dome displacement of your pistons you can plug it and the headgasket thickness into that handy dandy link I provided amidst my stupidity and figure out what the hell your CR is exactly.
Old May 1, 2002 | 12:38 PM
All Motor EG's Avatar
for now retard timing all the way and if it still pings run race gas. i know its a lot of money but it sux to **** up your motor.
Old May 1, 2002 | 01:28 PM
non-VTEC's Avatar
i say take the head to a good head porter and have them open up the chambers and make them larger.......if you can drop the CR just under 12:1 i'm sure you will be fine......
here's my head with 84.5mm chambers. (46.2cc)
Old May 1, 2002 | 01:53 PM
Halo's Avatar
Default Re: How can I lower my compression from 12:5:1 to 11:5:1??????? (non-VTEC)
Well i just did a little research on my JE pistons and all I can say is CRAP!!!!!!!!
My dome CC=4.8cc
Head is slightly milled .010 so my head cc is roughly= 39cc
bore=85
stroke=89
with stock headgasket I am fricking nearly 13:5:1!!!!!!!!!!!! No wonder I was pinging like crazy on pump gas!!
I can get near 11:5:1 if I just slap on a .067 headgasket. Can a good porter go from 39 to 45cc on the head?? Or is this too much for the combustion chamber?.
If I can take the chambers to 45 then all I need is .029 headgasket to be at 11:7:1
Old May 1, 2002 | 01:58 PM
non-VTEC's Avatar
sell the GS-R head and get a B16 head?
but a good head porter can probably take the square shape of the GS-R head chamber and make it round like the LS and B16 head.
ask a few good hear porters and see what they say........
Old May 1, 2002 | 02:58 PM
riceboy's Avatar
non-VTEC, is that head on your motor yet? It looks nice, what type of motor are you building again, and is it installed yet?
Old May 1, 2002 | 03:03 PM
non-VTEC's Avatar
Default Re: How can I lower my compression from 12:5:1 to 11:5:1??????? (riceboy)
yes thats the head on my engine......
these are my rods:
my pistons:
my valve train components:
that's enough pics for now........more details later......
Old May 1, 2002 | 03:09 PM
MrFatBooty's Avatar
What are you using to compute your CR values? I put this stuff into the calculator I'm usin (the c-speed one I linked):
Bore: 85mm
Stroke: 89mm
Combustion chamber: 39cc
Dome: 4.8cc
Headgasket: .029 (OEM)
Piston-to-deck height: .030
Which yielded about 12.8:1.
When I changed the headgasket thickness to .062 it gave me 11.64:1.
Hmm...
Old May 1, 2002 | 07:13 PM
Halo's Avatar
yes you are correct... my friend is the one who ordered and installed the gasket so I took his word for it. According to the link I should be at 11:6:1, except I have been in 11:8:1 setups that didn't ping even with stock timing, so either my timing is off or I have a thinner gasket? crap!
Old May 1, 2002 | 07:14 PM
Halo's Avatar
your set-up looks really nice non-vtec! Especially those valves
Old May 2, 2002 | 01:11 PM
non-VTEC's Avatar
i got a killer deal on those......from a really cool HT.com member!
1SIKZ06
Mar 4, 2009 12:59 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
done
Sep 7, 2004 09:57 AM
I_know
Dec 21, 2002 07:07 AM
type autox
Sep 20, 2001 04:44 PM
