Xenocron.com - Chip kits, ECUs, Moates, Conversion Harness, Fuel Pump, Injectors...and MORE!
OBD1 ECU Chipping Kit (SST eprom chip)
http://www.xenocron.com/chipping-kit...cus-p-277.html
Chip your own OBD0 or OBD1 ECU
OBD0 - PM6, PR4, PS9, PW0, PR3
OBD1 - P05, P06, P09, P28, PR4, P74, P75, P61, P72
JDM OBD1 - P08, P29, P30
OBD1 USDM VTEC Conversion Kit
http://www.xenocron.com/vtec-convers...ecu-p-278.html
Add VTEC circuitry to your non-VTEC US ECU
OBD1 - P05, P06, P09, PR4, P75
PURCHASE FROM THE SITE
Motorola 2.5 Bar Map Sensor Kits
http://www.xenocron.com/motorola-25-...kit-p-194.html
3 Bar Map Sensor Kits
http://www.xenocron.com/3-bar-map-se...-gm-p-195.html
Aries ZIF Socket
http://www.xenocron.com/aries-zif-socket-p-196.html
SST Chips (10 pack)
http://www.xenocron.com/eprom-chip-s...ack-p-151.html
ORDER FROM THE SITE
USB Datalogging Kit
http://www.xenocron.com/xeno-usb-dat...-kit-p-72.html
Serial Datalogging Kit
http://www.xenocron.com/xeno-serial-...able-p-74.html
Moates Ostrich Emulator
http://www.xenocron.com/ostrich-20-u...tor-p-102.html
Moates BURN1 USB Chip Burner
http://www.xenocron.com/burn2-usb-chip-burner-p-88.html
Moates 2Timer Two Chip Board
http://www.xenocron.com/moates-2-timer-p-310.html
ORDER FROM THE SITE
Innovate Wideband Products
http://www.xenocron.com/wideband-c-25.html
ORDER FROM THE SITE
PLX Wideband Kits
http://www.xenocron.com/wideband-plx...s-c-25_88.html
Chipped ECUs
OBD1 VTEC and Non-VTEC ECUs
- Come ZIF socketed and include TWO basemap reburnable chips
http://www.xenocron.com/chipped-obd1...ecu-p-129.html
255 lph High Pressure Fuel Pumps
Bosch 044 Fuel Pumps
http://www.xenocron.com/bosch-044-fuel-pump-p-465.html
Injector Dynamics Injectors
Precision Injectors
As always we have some cost effective PACKAGE DEALS that include parts for DIY Fuel Tuning
ORDER PACKAGE DEALS
S300 Boost Package
http://www.xenocron.com/hondata-s300...age-p-285.html
KPRO Boost Package
http://www.xenocron.com/hondata-kpro...age-p-472.html
Check out the SERVICES Section of our website as well!
http://www.xenocron.com/services.php
Xenocron on Facebook
https://www.facebook.com/xenocron
Aries ZIF Socket
SST Chips (10 pack)
ORDER FROM THE SITE
USB Datalogging Kit
ORDER FROM THE SITE
ORDER FROM THE SITE
PLX Wideband Kits
Chipped ECUs
Precision Injectors
ORDER PACKAGE DEALS
S300 Boost Package
KPRO Boost Package
first business i ever did with on homemadeturbo.com for my first homemade turbo sohc setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Its that kidfolk »</TD></TR><TR><TD CLASS="quote">
first business i ever did with on homemadeturbo.com for my first homemade turbo sohc setup</TD></TR></TABLE>
Thanks for
Thanks for
<FONT COLOR="red">Just added a NEW Product</FONT>
OBD1 Tuner Harness
One side plugs into the stock OBD1 harness ECU plugs, the other side plugs into an OBD1 ECU. (pass thru harness)
This harness allows you to tap into all major sensors, power (12v) and ground on the ECU as well as send a Wideband voltage signal to the ECU without splicing into the customers harness.
Can easily save you 20 minutes of wiring/setup time and also tear down (no heat shrinking or electrical tape on wires you had to tap into.
Personally I use this to power my LM-1 when I tune. Can easily be used with the RPM Convertor to tap into the stock 0-5v sensor wires
The pigtail has the following included for easy access with add-ons or a simple volt meter:
RPM (ICM)
Power(12v)
TPS (Throttle Position Sensor)
ECT (Engine Coolant Temp)
O2 Signal Input
IAT (Intake Air Temp)
MAP (Manifold Absolute Pressure Sensor)
Ground
As always, our harnesses are guaranteed for life!
Intro Price: $139
OBD1 Tuner Harness
RPM (ICM)
Power(12v)
O2 Signal Input
Ground
Intro Price: $139
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">whats up bro, u have any 5151 switches? i need a few of them, like 10-20</TD></TR></TABLE>
yeah i have them, PMd you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrackSpeedRacing »</TD></TR><TR><TD CLASS="quote">bump
e-mailed ya Chris
Thanks, replied!
e-mailed ya Chris
</TD></TR></TABLE>Thanks, replied!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Themouse »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronicsinners »</TD></TR><TR><TD CLASS="quote">that tuner harness is an excellent idea
I'm not sure that people realize how much time and energy it can save
</TD></TR></TABLE>I'm not sure that people realize how much time and energy it can save
