40mm tranny axle seal - what part number? obd1 zc tranny
Old Sep 27, 2006 | 02:06 AM
liam821's Avatar
Default 40mm tranny axle seal - what part number? obd1 zc tranny
Im trying to figure out what the honda part number is for a 40mm axle seal for both passanger and drive seals on the tranny. I run not the standard 34mm, but 40mm axle splines (same size as the b-series) and use a 88-91 dohc zc half shaft. My diff is a Cusco LSD if it matters. The tranny is a jdm 92 obd1 zc tranny (its a standard s20 which is identical to a 92-95 civic SI just has a different diff and output spline size)
I tried a 90-91 honda civic AWD wagon - they are 40mm - but they dont fit in the tranny.
Anybody know? I've searched around and havent found an answer.
thanks,
liam
Old Sep 27, 2006 | 08:24 AM
Bense's Avatar
Default Re: 40mm tranny axle seal - what part number? obd1 zc tranny (liam821)
just get some DA teg ones, they should fit.
Old Sep 27, 2006 | 09:24 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: 40mm tranny axle seal - what part number? obd1 zc tranny (Bense)
yep....
Tore down a ZC tranny, used the axles seals in a B16 tranny, same part.
Old Sep 27, 2006 | 10:49 AM
liam821's Avatar
Default Re: 40mm tranny axle seal - what part number? obd1 zc tranny (Mista Bone)
Awesome thanks so much guys!
JDMister_EF9
Feb 13, 2007 11:48 AM
julio_bOostamante
Nov 21, 2006 02:07 PM
*Boostwerks*
Sep 14, 2003 11:03 AM
Toptul_Honda
Apr 22, 2003 12:13 PM
X
Dec 2, 2002 07:42 PM
