dsm turbo manifold & injectors on 91 f22??
Old Sep 26, 2006 | 07:40 PM
ateeb786's Avatar
Default dsm turbo manifold & injectors on 91 f22??
i heard you can use a 1st gen dsm turbo manifold on a f22..is that true? i know the bolts dont line up right but i heard it CAN work? Has anybody ever did this?
I heard dsm injector can fit to..is that true also??? oook if they do fit can i use them with out a turbo??
sorry if this was already answered or been though with it.
Old Sep 26, 2006 | 08:23 PM
BlUAc's Avatar
Default Re: dsm turbo manifold & injectors on 91 f22?? (ateeb786)
yes it will both of them there is a write up on homemadeturbo.com check it out
Old Sep 26, 2006 | 09:13 PM
AccordSleeperZzZ's Avatar
is this true for all f22's? vtec and non?
Old Sep 26, 2006 | 09:44 PM
My292Ludes's Avatar
Default Re: (AccordSleeperZzZ)
All F22s and the H23 from the lude
Old Sep 26, 2006 | 10:51 PM
momstaxi's Avatar
Default Re: (My292Ludes)
only f22ax (90-93) will work
Old Sep 27, 2006 | 12:21 AM
raceACCORDingly's Avatar
and jdm f22b dohc
Old Sep 27, 2006 | 03:40 AM
teamlegacy's Avatar
Default Re: (raceACCORDingly)
The injectors can be run N/A, but why? You'd run way rich and would require a tune, and even still, it would do nothing for you except waste cause and run poorly.
Old Oct 3, 2006 | 07:47 PM
ateeb786's Avatar
Default Re: dsm turbo manifold & injectors on 91 f22?? (BlUAc)
thanks
Old Oct 8, 2006 | 05:19 AM
standbackimapro's Avatar
The Manifold And Injectors will Fit,
In Order To Make the manifold FIt, You have to Grind Out a few of the Holes on the manifold, Very Easy
The Injectors will fit but you will either have to press them in really hard, or just get different seals
Old Oct 8, 2006 | 03:45 PM
ateeb786's Avatar
Default Re: (standbackimapro)
ok i understand how to put the turbo on, where all the piping goes and the fittings no problem. BUUUT i dont understand what i have to do with the computer (ECU). I live in Syracuse NY, i dont know where i can get it tuned. Frist of all what am i supposed to do with the ecu? Where can i get the chip? do i have to send the ecu out oor do it myself because i have no clue...i have to be guided with this mess.
I think after i understand how the computer for a turbo car works im going to start, buy everything together it'll be much easy.
I was thinking of t3 turbo, everyone says its good for a f22, hoping to get about 250 to 280 hp, thats fine with me.
no one has a fast accord out here.
Old Oct 8, 2006 | 04:42 PM
1lowsol2's Avatar
i gotta A/t with 205K think it can handle 6-8 psi?
Old Oct 9, 2006 | 06:27 PM
ateeb786's Avatar
Default Re: (1lowsol2)
thanks for the notice ill will do that. Where did you get you head bolts from? and how did you get the ecu setup to work?
I have a stage 2 clutch and a light flywheel.
Old Oct 10, 2006 | 06:09 AM
1lowsol2's Avatar
so if the manifold works that means the turbo will bolt right up and possibly the downpipe?
Old Oct 10, 2006 | 03:13 PM
teamlegacy's Avatar
The DSM downpipe won't fit without modification.
Old Oct 10, 2006 | 04:49 PM
1lowsol2's Avatar
so back to my original question, My accord has 205K on it and its a A/T can it handle 6-8psi?
Old Oct 10, 2006 | 05:53 PM
teamlegacy's Avatar
Check compression and do a leakdown. Do a full tuneup and change t-belt, water pump, etc. So the engine might be able to hang, but that auto will probably take a dump.
Old Oct 11, 2006 | 08:35 AM
1lowsol2's Avatar
well i got a different tranny in it now that has about 132K on it
Old Oct 11, 2006 | 11:25 AM
1lowsol2's Avatar
yeah i've considered a 5spd swap many times. I dunno if i'd be able to pull it off myself. But it would be well worth it. I'd like the car alot better if it was a 5spd. I've read the How-To on the 5spd swap a couple times i'd probally need some help with it from another mechanic if i were to do it.
Old Oct 11, 2006 | 11:46 AM
BLK Accord EX 97's Avatar
hi are you selling a f22b1 kit if you are im interested how much are you asking?
lkldsucs
Jul 10, 2006 03:54 AM
importdude2000
Apr 20, 2006 12:50 PM
preludef22a
Oct 18, 2004 01:38 AM
airwalk07143
Dec 3, 2003 06:25 PM
paulzy
Sep 3, 2001 12:18 PM
