NO VTEC CROSSOVER!!!!!!!!!!!!!!!
ok have a 97 ex coupe and i just swap in a b16a2 and i use my ex harness wit the ex ecu(until i get a obd2a-obd2b harness to use the b16 ecu) i have the engine light on and i was wondering if i can get the codes manually like on the 92-95 civics or do i need a scanner? also when the car is cold u gotta give it gas to turn on and when the car is hot it idles at 2000 rpm and of course vtec is not opening. any suggestion guys? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin »</TD></TR><TR><TD CLASS="quote">any suggestion guys?</TD></TR></TABLE>
Get the right ECU?
Are you really that stupid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i have the engine light on and i was wondering if i can get the codes manually like on the 92-95 civics or do i need a scanner?</TD></TR></TABLE>
You can pull the codes manually.
Get the right ECU?
