b18c5 burning oil
i got a 1998 b81c5 motor in my 92 si hacth and wen i drive the car hard i smell the oil burning and i got light grey smoke coming out the tail pipe can i cure that by using a better oil meaby synthetic or a thicker type instead!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dipset1 »</TD></TR><TR><TD CLASS="quote">i got a 1998 b81c5 motor in my 92 si hacth and wen i drive the car hard i smell the oil burning and i got light grey smoke coming out the tail pipe can i cure that by using a better oil meaby synthetic or a thicker type instead!</TD></TR></TABLE>
are you sure its burning oil? are you checking your dipstick? Are you just going off the smell alone. Usually light smoke would indicate oil. a blue-ish/white smoke = coolant, and black smoke = fuel.
Is your block stock? I would prob. do a compression check first then leakdown afterwards. could be valves, could be blowby.
give some more info on your setup.
ye the block is stock the dipstick does not show any sighns of oil loss and i smell it in the interior after i open up vtec a couple of times other then that it drives wit out the smell or any sighn of grey smoke out the tail pipe the motor has around 100000
I've seen quite a few ITR's fry headgasket's...but I'm not jumpin to the line to say it's that...I would just definately say it's a possibility. Are you sure the smoke's grey and not greyish/light blue?
Do a compression & leakdown test :-\.
EDIT:
PS: How often are you filling up the oil? Is it noticable?
EDIT:
its more than likely your valve stem seals, its a common problem in dohc vtec engines. my gsr has the same problem. but before you jump to conclusions do what others have said and to a comp. test and leak down that should pinpoint your problem.
to blue smoke in vtec!
so would that be normal that it burns oil only at vtec stages cause i got some ppl telling me that most honda motors do that other say its gonna lead to serioes problems
if you cant do compression or leakdown just yet, try changing you oil, and see if what the old oil looks like. if it looks like chocolate milk, them you HG is gone. also look at your spark plugs. these little things will tell you a lot.
Duhul
May 20, 2010 11:18 AM
Kisses_89_HB
16
Nov 14, 2003 09:41 AM
