ZC to D tranny
Old Sep 26, 2006 | 05:20 PM
93accordsleeper's Avatar
Default ZC to D tranny
Will a ZC engine but up to a D tranny without mods and still use stock mounts. What about a whole ZC swap what do I need. Thanks guys
Old Sep 26, 2006 | 06:39 PM
Targa250R's Avatar
be professional
Default Re: ZC to D tranny (93accordsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93accordsleeper &raquo;</TD></TR><TR><TD CLASS="quote">Will a ZC engine but up to a D tranny without mods and still use stock mounts.</TD></TR></TABLE>
An '88 or later ZC engine will bolt right up to any '88-00 D-series transmission. Keep in mind that all ZC engines are D-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What about a whole ZC swap what do I need.</TD></TR></TABLE>
That depends on which ZC you are intending to swap (there are several different engines that were stamped "ZC"), and which car you are swapping it into. You neglected to include that pertinent information . . .
Old Sep 27, 2006 | 08:53 AM
unbelievableEG's Avatar
the trannys will bolt up fine but you have to remember the axles size is bigger on the ZC then any other D-Series
Old Sep 27, 2006 | 09:00 AM
Targa250R's Avatar
be professional
Default Re: (unbelievableEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unbelievableEG &raquo;</TD></TR><TR><TD CLASS="quote">the trannys will bolt up fine but you have to remember the axles size is bigger on the ZC then any other D-Series</TD></TR></TABLE>
It won't matter if he is not using a ZC differential and intermediate shaft.
Old Sep 27, 2006 | 09:03 AM
nemesismachine's Avatar
Default Re: (Targa250R)
I have a ZC in my 93, and it bolted up fine. SOHC.
ej2r
Nov 22, 2006 03:21 AM
ninjapanda
May 25, 2005 10:02 PM
Horse_Balls
Jun 18, 2004 01:31 PM
LSVTECKING
Sep 9, 2003 05:42 PM
Ronin Panda
32
Apr 23, 2003 06:45 PM
