WHAT DO I NEED TO REPLACE???????????
I have to fill my brake fluid up like every month, i think its leaking. Do i need to replace anything like the clutch master cylinder or slave cylinder or is it something else. I think its leaking inside the car, and doesnt look like its leaking in the engine bay, here i got pics:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrownEyed »</TD></TR><TR><TD CLASS="quote">master cylinder got to be replaced. and check the slave cyl for any leak sign.</TD></TR></TABLE>
True. That MC is leaking, albeit slowly.
To check your slave cylinder, place a piece of cardboard under the tranny and let it sit overnight. The s.c. is on the side of the tranny closest to the radiator. It looks like a little dirty water pistol or something.
I disagree with the previous opinion, I think it's leaking pretty badly since the carpet is stained in the first pic. Definitely change the master and check the slave cylinder while you're at it. Remove it and check for leaks under the boot.
If you let this go and you run into not having enough clutch release (low fluid) then you're wearing your tranny unnecessarily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">I disagree with the previous opinion, I think it's leaking pretty badly since the carpet is stained in the first pic. Definitely change the master and check the slave cylinder while you're at it. Remove it and check for leaks under the boot.
If you let this go and you run into not having enough clutch release (low fluid) then you're wearing your tranny unnecessarily.</TD></TR></TABLE>
Ah I see the leaked carpet now. I stand corrected.
I went to the Honda Doctor and asked them how much would it cost to replace MC, they said u should have the SC replaced also which all of its gonna cost about $500, this seems to expensive should i go to the dealership?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura »</TD></TR><TR><TD CLASS="quote">I went to the Honda Doctor and asked them how much would it cost to replace MC, they said u should have the SC replaced also which all of its gonna cost about $500, this seems to expensive should i go to the dealership?</TD></TR></TABLE>
No. I got the M/C, S/C replaced by a local grease monkey for about $330. Using genuine Honda parts. Go around to some stores and get an estimate. Place a piece of cardboard under your tranny overnite to see if the S/C is leaking. If it ain't broke, don't fix it. The M/C and S/C do not have to be replaced at the same time, they are just trying to make some $ off you. Go to some local shops and get some other estimates.
hell no, i believe there is DIY post in ITR section. its pretty easy. just take a time.
OEM master cylinder is about right under $100 or very little over. and 3-4 bottle of brake fluid will be under $15.
dthug
11
Feb 21, 2006 07:05 PM
