Unorthodox Underdrive Pulley Set
Old Sep 26, 2006 | 04:31 PM
Mugen_DC2R's Avatar
Default Unorthodox Underdrive Pulley Set
I am thinking to get a Unorthodox Underdrive Pulley set. If i am going to install this pulley set, do i use OEM belts, or do i need to get different belts that are for this Underdrive pulley set?
thx in advance
Old Sep 26, 2006 | 05:04 PM
Mugen_DC2R's Avatar
Default Re: Unorthodox Underdrive Pulley Set (Mugen_DC2R)
anyone knows?
Old Sep 26, 2006 | 06:00 PM
Todd00's Avatar
I said I don't want a title!
It says what you need on the unorthodox website, at least it used to.
Old Sep 26, 2006 | 06:31 PM
Mugen_DC2R's Avatar
Default Re: Unorthodox Underdrive Pulley Set (Todd00)
thx
Old Sep 26, 2006 | 07:05 PM
white rocket's Avatar
Save your money. I have the full pulley set and all it did was make my lights dim . Seriously, there are better things you could get for the R.
Old Sep 26, 2006 | 10:07 PM
Mugen_DC2R's Avatar
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">Save your money. I have the full pulley set and all it did was make my lights dim . Seriously, there are better things you could get for the R.</TD></TR></TABLE>
What other things do u suggest me getting.
Modified by Mugen_DC2R at 2:46 AM 11/8/2006
Old Sep 26, 2006 | 10:36 PM
Dave_B's Avatar
Default Re: (Mugen_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
What other things do u suggest me getting. I want to make approx 200WHP or more without touching the bottom end. i want to get the most out of the engine. i know the pulley is only going to give me maybe 2WHP. I dun care if my light will dim, i mostly go to track day for fun w/ my car. If there are better things i could do i would do it instead of the pulley.</TD></TR></TABLE>
200 WHP with stock internals is completely possible. It starts with good quality mods. FWIW I hit 192 WHP with just intake, header, exhaust, IM gasket. So 200 is definitely do-able.
Old Sep 27, 2006 | 09:41 AM
type_r_jon's Avatar
different belts. I recommend just doin the crank pulley. The other 2 make no additional power. Remove your AC if you are mainly using the car as a track car.
Old Sep 27, 2006 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">What other things do u suggest me getting. I want to make approx 200WHP or more without touching the bottom end. i want to get the most out of the engine. i know the pulley is only going to give me maybe 2WHP. I dun care if my light will dim, i mostly go to track day for fun w/ my car. If there are better things i could do i would do it instead of the pulley.</TD></TR></TABLE>
Comptech Icebox, taper-bored OEM TB, IB intake manifold, Outlaw TB/IM spacer kit, UR puley kit, Toda header, T1R testpipe and catback, cam gears, Hondata s200 tuned. I made 196whp on bone stock internals.
Take out your a/c and power steering, get a good I/H/E set up, get it tuned and you'll be close to your goal
Old Sep 27, 2006 | 11:20 AM
BudMan's Avatar
Take out your a/c and power steering, get a good I/H/E set up, get it tuned and you'll be close to your goal </TD></TR></TABLE>
It's amazing how much better quality parts there are now than when goodies were put on my car. The header is still a dc-sport LS header 'cause there wasn't one for the R at the time....btw - '98 still rox, even if it's only 178 hp.
Old Sep 27, 2006 | 02:52 PM
Mugen_DC2R's Avatar
Default Re: Unorthodox Underdrive Pulley Set (type_r_jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
200 WHP with stock internals is completely possible. It starts with good quality mods. FWIW I hit 192 WHP with just intake, header, exhaust, IM gasket. So 200 is definitely do-able.</TD></TR></TABLE>
Modified by Mugen_DC2R at 2:49 AM 11/8/2006
Old Sep 27, 2006 | 03:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">I already have Mugen Intake, Toda header, Apex N1 exhaust w/no cat, Toda B, Bored TB, Port and polish head and IM, and other little things. And also Apex'i Power FC.
My car is not tunned yet. I know tunning is everything. Just because i have a Power FC, I want to put all my mods in b4 tunning, to squeeze every bit of power on stock bottom end, because tunning power FC is expensive. I asked 2 dyno shops which have the software for tunning power FC, they quote me 800-900 bucks for fully tune. So i will only want to get it tune once.</TD></TR></TABLE>
Well ****, if you're that far along then it may be beneficial to get the pulley set. The crank pulley does not have a harmonic balancer and some have said that it could cause worn bearings, crankshaft, etc. Mine have been on for well over two years and I haven't had any problems though.
jim9
Jul 6, 2010 06:55 PM
b18-crx
Jan 19, 2009 08:53 PM
EGB18C
Jan 27, 2008 07:35 AM
