Cooling fan switch ?
Old Sep 26, 2006 | 04:09 PM
bigrballerz's Avatar
Default Cooling fan switch ?
The motor kept overheating so what it might be ? The fan is working pretty good , do you think it is fan switch relay ?
thanks
Old Sep 26, 2006 | 04:56 PM
Default Re: Cooling fan switch ? (bigrballerz)
Old Sep 26, 2006 | 11:45 PM
BLKGSR24's Avatar
If the fans are working then your fan switch must be good. Overheating could be from low coolant, bad T-stat, air in the cooling system, bad water pump, leaking radiator or possibly a blown headgasket (I'm sure there's more that I missed). You need to provide more info, like does it overheat at idle, while driving, on the freeway????? Are both radiator hoses hot, or is the bottom one cold?? Does your heater blow hot air or is it cool when you turn the heat on full blast?? Is coolant disappearing from the radiator or is the overflow bottle filling up?? If you don't give more info to your problem then it's almost impossible for one to help you over the internet.
Old Sep 27, 2006 | 12:23 AM
__oversea's Avatar
fan only comes on when car is not moving.
it could be a many things like blkgsr24 posted.
start checking one by one
Old Sep 27, 2006 | 07:33 AM
Infamous508's Avatar
Default Ok here it goes.
I just had the motor swap which the old motor had a head gasket blew and then I bought new motor which it is around 90 k on it n put in the car. I haven't drive the car yet so it gets hot about 5 to 10 minutes and the top hose gets alot of air growing big and hot so then the idle is acting up little bit. The rad looks fine which it stays same pace as well. I even tried to do the rad bleed to let the air come out which it stays the same thing so what it might be ?
Yes , two hoses is hot and the rad is full with anti freeze-water....so what it might be ?
Thanks !!!
Old Sep 27, 2006 | 07:39 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: Ok here it goes. (Infamous508)
It can be your thermostat, I would try that first, their cheap.
Old Sep 27, 2006 | 07:43 AM
Default Re: Ok here it goes. (Kiniku Chunks!!!)
Okay , updated .....the buttom hose is HOT ...the top hose is HOT with air....is it t-stat ?
Thanks
Modified by Infamous508 at 8:54 AM 9/27/2006
Old Sep 27, 2006 | 08:15 AM
Now the rad on left upper plastic got cracked which it was too much pressure .
Old Sep 27, 2006 | 12:42 PM
Okay , I just put in new T-STAT and it runs the same ( overheating and the fan is not working ) however i tested the fan ..the fan is working on positive n negative battery.
The top hose is still in the air and i did the bleed thingy ...what else ?
Lando555
10
Mar 12, 2019 04:27 PM
Ali1128
Honda CR-V & Element
16
Jan 31, 2012 06:21 PM
zacheryleatherw
Jun 27, 2011 02:52 PM
hotcivicsi
19
May 15, 2009 01:54 PM
juicedricer
Jan 21, 2003 04:55 AM
