StartUp Problem after Gas Fill....Need Opinions Im stumped
Every since i bought the car its had this problem, but now that ive turboed it its worse....anyways
After im done filling my car, I go to start it the car starts for a second and dies....so i crank angain...the car cranks cranks cranks And then barely starts up.
This happenes only after I put gas in the car. ANy other startup and the car is fine....Im stumped...
any CEL, how has it been running before? what type of problems before? what year car? what motor? it can be anything from fuel, spark, vaccum(since you're turbo). we need more here.
I dont really think the setup matters really....The car starts up fine from a cold start....this only happens after i go to the gas station and do a startup there. When the h22 was na i had the same problem.
Ive tried putting the key in the on postion a couple times before starting the car..and it didnt help
I dont get any cels, the setup is
2000 ex
h22a od1
1000cc injectors
t3/t4 borgw warner
255 walbro pump
etc...
2000 ex
h22a od1
1000cc injectors
t3/t4 borgw warner
255 walbro pump
etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhed-w »</TD></TR><TR><TD CLASS="quote">gotta be in the gas tank-bum fuel pump or something? how about the fuel filter?...just my 2 cents</TD></TR></TABLE>
When i had the stock pump it did the same thing now i have a walbro 255, and fuel filter is changed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">what year is your car? Does it depend on how much gas you put in? Will it do it even if you only put in a few gallons?</TD></TR></TABLE>
its a 2000, Nope it doesnt matter how much gas i put in it,.
i use to have the same problems... it might be your main relay... if it is hot outside and you drive for a bit, turning off the car and turning it back on will not sometimes start.
what i do is just leave the engine on, ebrake up and fill up gas. dont be scared... you wont blow up the gas station... been doing this for 4 months now.
the thing that gets me is he says it only happens when he shuts it off at the gas station. Can you drive somewhere, shut it off and start it back up? I'd try draining the gas tank. Otherwise, invest in a fuel pressure gauge, and have someone watch it next time you go to the gas station.
