Skunk2 Everything - A Dyno Story
Well I was at the dyno yesterday to see if all my work and cash has payed off. When I started my car was at 150whp and when we finished it was at 172whp with max torque at 116. I would say the tuning time was well worth it. The only real tweaks we made were moving the base timing to 18 degrees and messing with the fuel maps in my Hondata (my buddy was there with his stage 4 setup). The cam gears we found to work best at zero for both intake and exhaust side for the skunk2 stage 2 cams. Any adjustment on those would rob Peter to pay Paul on the power curve so setting it at zero left a nice smooth curve. From a little after 8000 rpm to 9500 rpm is where the power is (stays between 168-172whp). The torque remains fairly flat throughout the whole chart. I will get the chart up once I get around to scanning it in. Also got good video, but again go to find time to get it posted.
On another note, I dropped the Act SS/HD, ITR Flywheel and LSD in my car this past week end. I must agree with those who said it in the past... LSD RULES!
So if your cam gears are both at 0, are you going to keep them for possible future mods, or just go back to the stock cam gears?
Those are some good numbers going on stock compression. I think with ITR pistons and a little more tuning would bring you very close to the 200 w.h.p. mark.
Is the header a regular DC 4-1 or JDM? A good header with 2.5" collector would free up some more top end too.
i think there must be something missing or some better tunning is needed, my friend got 168 hp out of his b16 with the stage 1's! stock compression and no hondata. i think you can get a lot more power out of you setup.
i would expext bigger gains than that! i heard with those skunk cams u could be close to the 200hp mark and better tq.
Stage 1s make awesome numbers in B16s because the cams are well-matched to the long dwell at TDC.[/QUOTE]
yeah but never the less, with the larger displacement and more aggressive cams i'd exepct much more than 4 hp
"Stage 2's make 5 more hp than Stage 1's." Quote from Skunk 2
If he gets rid of that header and gets a real 2.5 header he will see significant gains in vtec. As for the cam settings, all motors are different and obviously his likes 0,0.
Sure I could have achieved 180-185 or maybe better with what I saw from messing with the cam gears but I chose to have that power in the low in middle of the RPM where I use it most (a nice smooth upward curve). Not on the top. And as for the vtec, it is set correctly. The dyno proved that.
dude who is doing your tuning? im gnna say it those numbers are pretty pathetic considering your setup. first of all your vtec is set way to high and with larger aftermarket cams any timing is better than stock timing on your cam gears! ive never hard or seen in my life a car still recieve stock timing after bigger cams were insatlled? fire your tuner and have your mom tune it trust me u will get better numbers.
Most larger aftermarket VTEC cams require the VTEC crossover point to be set a well over the stock crossover point to yeild good gains. And from what I've seen, cam gear tuning in most cases just moves the hump in the powerband up or down the rpm scale. Having them set a 0 probably gives him just the right balance of low end and top end that he is looking for. You need to learn a little more about what you're talking about before you start criticizing someone's hp gains.
yea i feel like you should be making more power --- jdm 4-1 and test pipe or carsound will probably open up alot. itr pistons will do wonders too.
later
-rob
later
-rob
Just retune it,don't go out buying headers and pistons just RETUNE it.The jdm 4-1 isn't gonna give you an extra 25 ponies to the wheels over the 4-1 your using. But not bad for a car thats 7 years old.
The primary lobes on the Stage 2s are larger than stock as well as the secondaries, so they make more power both before and after VTEC. Bigger primaries means you have to move the VTEC point up. You do not "throw your midrange out the window" by getting them.
Your "knowledge" or rather the lack thereof is in question because you posted in an argumentative manner and spell like a 10-year-old.
And no, you do not make some very strong points.
I have only one suggestion as far as freeing up some ponies without buying a new header, exhaust etc: your stock cat is probably clogged up with all of the smog particles that it's collected over the last 7 years and restricting exhaust flow.
Again retune it,I've seen GSR's with ITR cams and no 2.5 run 175whp.
[Modified by MPH, 4:58 PM 5/1/2002]
my argumernt about the vtec point was that it was to high.
