What rout should i go?
Old Sep 26, 2006 | 01:12 PM
DImages56's Avatar
Default What rout should i go?
i was looking at the stats of a gsr motor and a si motor. they both have the same bore of 81.0 mm. but the gsr has a stroke of 87.2mm while the si has a stroke of 77.4. hence the displacement difference.
a poor man type r motor is a b16 head+gsr bottom+pistons
can i just swap a gsr crank into a b16 motor to gain the displacement (to get same power as a poor mans typr r power), or is there a difference in deck height? or is there something else im missing? is there any weaknesses of just swapping out the crankshaft vs. the whole gsr bottom?
so what would be better i am on a budget???
option 1: build the poor man type r or option2: just swapping out to a gsr crank
Modified by DImages56 at 12:40 AM 9/27/2006
Old Sep 26, 2006 | 01:23 PM
Syndacate's Avatar
Default Re: What rout should i go? (DImages56)
You'd be better off with whichever crank has a larger offset. I don't know the numbers off hand but that would be better...for compression anyway.
Old Sep 26, 2006 | 01:30 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DImages56 &raquo;</TD></TR><TR><TD CLASS="quote">
(the poor man type r needs pistons because of the loss compression with the swapped block.)
i don't get what you are saying about the pistons for the poor man's type r?
i thought GSR(B18)+B16 head= poor man.
the pistons have nothing to do with it.
also, you just can't swap out cranks. i believe there is a deck difference as well.
Old Sep 26, 2006 | 01:34 PM
Mr Hammond's Avatar
a/k/a Jomo
Ok the "poor mans type r" is just a GSR block and B16A head. You will only loose about .2 point of compression as the PR3 casting head has the domed combustion chambers and the P72 castings have the pentroof design.
You would be better off just buying a GSR engine as you have the 1.8L of displacement, no compression loss AND slightly more aggressive cams. Just run a better throttlebody, intake manifold set-up and some quality bolt-on's and you are good to go.
Old Sep 26, 2006 | 11:41 PM
DImages56's Avatar
any other opinions or useful knowledge?
Old Sep 26, 2006 | 11:46 PM
chrisw85's Avatar
b16a/b and the b18c5r have different cranks but same deck heights as far as I know. Some people get the B16b engine and swap a type-r b18c5 crank in for more stroke.
Old Sep 27, 2006 | 07:56 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">b16a/b and the b18c5r have different cranks but same deck heights as far as I know. Some people get the B16b engine and swap a type-r b18c5 crank in for more stroke.</TD></TR></TABLE>
Not exactly.
B16A/B17A share same block.
B16B/B18C/1/5 share same block.
A B16B is essentially a B18C-R w/ a B16A crank and different length rods in it.
kotton909
20
Jul 17, 2007 03:41 PM
the.hamburglar
Nov 13, 2005 10:25 AM
JDMlyfestyle
Jun 14, 2004 01:06 PM
Propulsion
22
Oct 31, 2003 01:16 PM
SPEED123
Aug 7, 2003 04:23 PM
