Ignition Timing Steps (
Ok I have searched and just want to make sure i understand all the steps.
I jump the service connector
Let the engine run to temp (fan comes on)
Then Take the light and aim it down at the crank and adjust the dist. so it is 16BTC
Now when all this is happening the engine should be idling at 750 rpm
Are these the right steps?
Thanks
Thanks
If you go here It will tell you what to do. The motors are the same.
http://www.g2ic.com/tegtips/engine/7.html
sageuvagony
Aug 10, 2008 04:18 PM
