Best / Easiest way to measure offset
Old Sep 25, 2006 | 11:17 PM
pushlatency's Avatar
Default Best / Easiest way to measure offset
Hey, I recently picked up a set of (what I believe to be) Enkei RP0-2. They're 15x7 in 8 lug (4 x 100 & 4 x 114), each have "38" stamped on the insde of the rim, but I'm not really sure if this is the actual offset or not. Can anyone suggest an easy way to measure it?
Thanks, and forgive me if this has already been covered.
Harris
Old Sep 25, 2006 | 11:42 PM
vtecsi00's Avatar
Default Re: Best / Easiest way to measure offset (pushlatency)
i believe that the offset is 38 on the enkei rpo-2......one way is to take a tape measure and use a straight edge on the back of the hub......put the straight edge across the backside of the lip and take your tape measure and see what the measurement is in inches.......if it reads 5.496 inches then that is the correct offset.........
k20rex
Mar 1, 2012 09:21 AM
1337 Si
Sep 27, 2011 12:13 PM
jdmland
Sep 20, 2008 12:39 PM
mahleeh
Sep 9, 2007 01:23 AM
grngsr01
Oct 7, 2002 02:59 PM
