tranny noise......any suggestions??
the tranny seems to be smooth while accelerating, however when i release the gas pedal and the tranny is slowing the car down it sounds like the car is whining or congested. Its tough to explain.
also, when i put the car inn neutral and let it coast from say 20km/hr the tranny chatters....u can hear it slowing down. Im sure its the tranny and not the motor.
anyways i dont think any of these are normal....any suggestions before I take it to the dealer??
Whats up dude?
Welcome to my to my life. I've had that exact same thing for a while. It's your main tranny bearing (throwout bearing). It's pooched. Needs replacing.
At idol in neutral, listen for a humming/chattering sound ..... now press in the clutch. Sound goes away? Then quickly release the clutch ... sound comes back? Throwout bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 ITR »</TD></TR><TR><TD CLASS="quote">
No, the throwout bearing works <U>only</U> when the clutch is pressed. If it goes away when you press down an internal tranny bearing, almost always the front mainshaft bearing aka input shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">No, the throwout bearing works <U>only</U> when the clutch is pressed. If it goes away when you press down an internal tranny bearing, almost always the front mainshaft bearing aka input shaft.</TD></TR></TABLE> This guy is absolutly right, Your gonna have to pull the tranny and replace the main bearing(s) While you have it out I suggest changing the clutch and throwout bearing so that it is totally fresh. This is a common ITR problem. More $....Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 »</TD></TR><TR><TD CLASS="quote"> This guy is absolutly right, Your gonna have to pull the tranny and replace the main bearing(s) While you have it out I suggest changing the clutch and throwout bearing so that it is totally fresh. This is a common ITR problem. More $....Good luck
well if you guys are correct, than my local dealer is paying for it lol.....my whip is still under warranty thank god
how long does something like that take to do, a few hours or a whole day??
I takes at least a day, the tranny needs to be pulled, disassembled and rebuilt. Make sure that whoever does it inspects all of the internal parts(syncros, gears etc..) better to fix it while the tranny is already off than later.
I got a quote from a local Canadian Acura dealership for around $2000CDN to replace the clutch and synchro 2-3, so it's going to be in that order to replace the input shaft bearing as well.
rocketfuelcerx
Sep 25, 2005 08:18 PM
