aluminum flywheel question
Old Sep 25, 2006 | 08:33 PM
hotrodlincoln's Avatar
Default aluminum flywheel question
do they recomend anti seize on the flexplate bolts for an aluminum fly wheel
Old Sep 25, 2006 | 10:05 PM
inspyral's Avatar
If I remember correctly, Helm's tells you to put Loctite on the flywheel bolts before torquing them down. You don't want those things coming out...
Old Sep 26, 2006 | 10:07 AM
Default Re: (inspyral)
im wondering about the flex plate/clutch bolts theyr going into aluminum so im pretty shure loctite is a bad idea verify?
Old Sep 26, 2006 | 03:44 PM
inspyral's Avatar
Oh, my bad, I thought you meant the flywheel bolts that go into the crank. I would just torque the pressure plate bolts to spec unless the flywheel manufacturer specifies using anti-sieze compound.
Old Sep 26, 2006 | 03:50 PM
i dont have any paper work on the flywheel it came w the car
Old Sep 26, 2006 | 04:10 PM
inspyral's Avatar
Do you happen to know who makes your flywheel? I found some documentation for Fidanza aluminum flywheels, which are pretty widely used if you want to use them as a point of reference:
http://www.fidanza.com/Files/f...2.pdf
bboylito
Apr 30, 2005 10:27 PM
jdub db8
Jun 5, 2004 06:22 PM
vtec69
Apr 12, 2003 10:23 AM
vtec69
Oct 30, 2002 04:59 PM
3rdGteg
Sep 3, 2002 09:52 PM
