RSX vs RSX Type S differences?
I'm sure this has been covered, but is there someplace that breaks down the exact differences between the two cars? I know the engine is different, but I was looking for other mechanicals, such as swaybar size, stock spring rate & shock valving, car weights, etc.
Considering trading my GF's 99 Civic EX for a base RSX cloth 5-speed. For her, I don't think the $3K Type-S premium is worth the upgrade. Plus, the stock RSX falls into a better autox class
Found good link:
http://www.hondanews.com/Forms/acura/RSX/index.html
Gives a decent technical rundown.
I drove the base and the type S. She would never know the difference between the two, and the base seems to pull a little better in lower gears. Plus, 3K is a good chunk of change.
The base would probably make a better autoxer too
But if I were buying, I'd get the S. I'm not, so it's whatever she likes and can afford. The tech. specs, besides the motor, are pretty much identical between the two.
jdmintegralsvtec
Sep 25, 2006 05:06 PM
akademiks5686
30
Feb 18, 2005 09:30 PM
