knocking sound right after starting engine, but then goes away??
as soon as i start my engine i can i hear a ticking or knocking noise coming from the engine, but it only lasts a second or two then runs fine. does anyone know whats happening?
josh
josh
Bump, I got the same problem, sounds like a knock or bump then goes away in like 1 second. For me it only happens on cold starts.
Guest
Posts: n/a
YEP. It is valve related. I say it's cold start or maybe one or two valve is off.
Anyhoo, get a Valve Adjustment at the mechanics. For $55 bucks. It's a good maintainance. Every car needs one every so often.
When I had my Valves Adjusted..It just ZINGED and ran a lot more efficient.
You could do it yourself, but it takes time.
mine did the same thing before but i have only heared it once. I thought it was carbon bounceing around but i dont no i have not heard it sence then. it was also on a cold start for me too.
hondapwr
11
Nov 15, 2005 12:15 PM
Comptech98GSR
Aug 27, 2002 08:55 PM
