weird vibration (not a noob cannon vibration question)
I have a weird vibration between 2000 rpm and 4500 rpm in 1st 2nd and sometimes 3rd gear at about 25-40% throttle on a 92 eg with a b16a...
the vibration does not come through the steering wheel usually but it does at the worst, it usually just shakes the car its self..
it is not a bad vibration per say, and it is there some times and not other times at verrying degrees of bad-ness...
the vibration is not present in 4th or 5th gear
the car has avid mounts, hybrid axels with new integra halfshafts
does anyone know what it could be?
no, I specifically checked to makesure it wasnt a salvage or an accident..its clean.
it almost feels like theres somthign stuck to a driveshaft causing it to be off balance at times or somthing..
is that even possible?
I should of also added that this vibration has just appeared about 100 km ago, and wasnt there before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemm »</TD></TR><TR><TD CLASS="quote">have u found out the vibrations yet cause im havin the same problem im thinkin clutch problems but not sure let me know whats up....</TD></TR></TABLE>
ya im kind of worried about that, it has a bully stage 1 clutch and a findanza flywheel kind of worried the guy who put it in might of done it wrong, but i dont see how you can even do that its a pretty simple task.
im leaning towards an inner cv joint problem does anyone have experiance with that?
Modified by DTS at 7:17 AM 9/26/2006
The motor mounts you have are stiff, they can shake your car and make things viberate.
Are you saying its something in the interior? or in/aroudn the engine bay?
i had a similar vib. when i torn the driver side motor mount.
The one near the timing belt.
With the bad mount i was able to move the engine back and forth by hand.
Not so with the new mount.
Good luck.
Good luck.
drumsy
20
Jun 28, 2002 10:04 PM
