oil problem 92lx f22a1: maybe headcylinder/gasket
Old Sep 25, 2006 | 06:07 PM
Smokeeey420's Avatar
Default oil problem 92lx f22a1: maybe headcylinder/gasket
so my oil light has been on (not blinking)...so i bought a oil pressure sensor got it installed. (oil light gone)i drove away and a had some whiteish color smoke from my tailpipe. (noticed my radiator fluid had been disapearing before ). next day i looked under my oil cap and there was nasty,thick whiteish colored stuff in my oil cap, on the dipstick,and in the oil hole.
the level is just above the 2nd hole which i think is a little full. the oil doesn't look that clean and there is some oil by the switches under the dizzy.
now the oil light come on only if i drive for like 10 miles and it all messed up looking dim, dark ,light... looks crazy
so let see this is what i think white smoke =anti-coolant
and the white sluge in oil =water/anti-coolant = cracked /warped head / bad head gasket
it still runs for now i'm gonna get a compression check and leak down test to see where its excaping from soon ...............................any more ideas??
thanks
__________________
Old Sep 25, 2006 | 06:18 PM
KillerElfboy's Avatar
Default Re: oil problem 92lx f22a1: maybe headcylinder/gasket (Smokeeey420)
eevery now and then my oil light went nuts, but i dont think i ever had the sludge,
I'm gonna say if you're running fine, maybe your oil pump is about to go, cuz i was told i was running 3 lbs. of oil pressure but i drove to phila and back and no problems
Old Sep 25, 2006 | 06:23 PM
Default Re: oil problem 92lx f22a1: maybe headcylinder/gasket (KillerElfboy)
yeah i think i'm gonna get a oil flush and refill and see if it comes back...
Old Sep 25, 2006 | 06:24 PM
roblynn.org's Avatar
I'm betting head gasket. I'd get it taken care of ASAP, because you could be causing some damage to the head.
Old Sep 26, 2006 | 09:08 AM
hondadude's Avatar
Default Re: oil problem 92lx f22a1: maybe headcylinder/gasket (roblynn.org)
X2...... the exhaust will smell 'sweet' if burning coolant, but don't sniff it for too long.
carbon monoxide causes brain damage and can lead to posting on honda-tech.com
Ef4doorwagon
40
Aug 1, 2014 03:02 PM
soundFX
Jan 7, 2007 05:53 PM
NA JDM GSR
Apr 24, 2006 01:37 PM
G3gsr
May 20, 2003 06:17 PM
OldSchoolCrxSiR
13
Jun 26, 2002 09:41 PM
