integra bogging out....please help
ok so i have a 88 integra, obd-0 of course. About a week ago the fuel pump went out on it and it boggs out every time i give it gas. i know it is getting fuel to the head. checked injectors, some o rings were shot so i replaced them. still bogging. I put a b&m fpr on thinking the other one was shot (plus it looked a little rusty). changed the fuel filter with a brand new one. changed cap and rotor along with plugs and wires still doing the same damn thing. i honestly have no clue y it is doing this. no check engine light and no code on ecu. I did take it to many garages around my area all mechanics were clueless. a couple of them said maybe a clog in the exhaust. so i took off the exhaust still the same. also took out the o2 sensor. i also tried running it open throttle body, maybe not getting enough air. when i check the plugs they are a little black and not white at all so its getting fuel. Any help or input would help alot. i need HELP!!!
timing belt is fine. the fuel pump is located under the door not in the tank, i would have to drop the tank to check for sugar....lol.... i hope im not running on sugar
Wait it out until your tank is almost empty and then fill up. The same thing happend to me and i had no idea. I filled up on gas again about a week later and it was fine. Bad batch of gas?
myallmotoreg
Jun 1, 2011 04:36 PM
asiansgoweeee
Jul 14, 2004 08:26 AM
