I think my friend is getting the shaft on his new B!6!
Old May 1, 2002 | 05:58 AM
LSBeast's Avatar
Default I think my friend is getting the shaft on his new B!6!
He has his new first gen sitting in the garage, and is not very familiar with what he has. They told him his engine had ITR pistons, GSR head and, GSR tranny.
I'm trying to help the guy out. I know for a fact that tranny is cable. So that means it's impossible to be a GSR tranny. The valve cover on the engine is a B!6 valve cover. I don't know if the GSR valve cover looks any different. They will probably fit on any B-series head. Is it possible to put the ITR pistons in a 1.6?
anything will help fellas
Thanks.
Old May 1, 2002 | 06:29 AM
1's Avatar
Default Re: I think my friend is getting the shaft on his new B!6! (neo0024)
Sure, they are both 81mm bore.
Old May 1, 2002 | 06:37 AM
91SiKen's Avatar
92-93 GSR's had cable trannies. And they are very desirable for racing because of short gearing. HTH.
Old May 1, 2002 | 06:42 AM
markedOO1's Avatar
..it could be a 90-91 gsr tranny...they're cable.
Old May 1, 2002 | 07:00 AM
LSBeast's Avatar
Default Re: I think my friend is getting the shaft on his new B!6! (marked001)
Really! Thanks for the info
I looked all over the tranny for the name,
and found nothing. Where would I find out what
kind of tranny it is. How do know if its a GSR head?
Old May 1, 2002 | 07:49 AM
GraphiteAccord's Avatar
They never made a '90-91 GSR. only '92-93's, which had the most desirable trans, cause of the short gearing + being able to rebuild with US parts (unlike y1/s1) Also, ITR pistons will fit, any B series vtec valve cover will fit that car. Also, To see if it has a GSR head, look for ethier a P72 stamping, or look at the intake manifold, if it folds over down, then its a GSR, if it comes up, like on the itr, then its a B16 head. Also, B16 head will say PR3 i believe.
Old May 1, 2002 | 07:51 AM
markedOO1's Avatar
Default Re: I think my friend is getting the shaft on his new B!6! (GraphiteAccord)
sorry for the misinformation
Old May 1, 2002 | 08:07 AM
LSBeast's Avatar
that info helps out alot Graphite
DC4xRacer
Aug 3, 2004 08:17 PM
elmalouno
Jun 7, 2003 09:48 PM
