Is balancing this motor nessesary?>
Old Sep 25, 2006 | 07:19 AM
sackdz's Avatar
Default Is balancing this motor nessesary?>
B18C5 ~35kmiles. stock, ~9k redline. Honda challenge car.
Im rebuilding with pistons (stock) and bearings (Honda) only and keeping everything else [bottom end].
I can get the piston/pin/rod sets to within .5 gram by mixing and matching. Thats close enough, right?
Either way, where is the best place to remove material from the piston and rod?
I was thinking if needed just hitting the piston with an end mill on the underside of the face, and the rod along the side (concave portion) down the length and closest to the big end.
I was thinking I didn't need to do an all out full balance. The flywheel is exedy 12lb. and the crank pulley is a CTR.
Old Sep 25, 2006 | 08:10 PM
sackdz's Avatar
just looking for a few opinions thanks. first bottom end build.
myjdmsucks
Engine Machining & Assembly
Oct 8, 2015 11:17 AM
sackdz
Oct 26, 2006 08:10 PM
satan_srv
Jan 3, 2003 10:36 AM
Adi Radoncic
Dec 8, 2002 02:44 PM
