Frame Damage Repair Estimate? (w/ pics)
Old Sep 25, 2006 | 04:15 AM
Chil709's Avatar
Default Frame Damage Repair Estimate? (w/ pics)
I'm looking to have some minor frame damage worked on next week. How much do you think these fixes should run at a decent shop?
Besides from the obvious need to replace the radiator support, there are three problem areas.
1 - Front face of frame member where bumper support mounts is bent inward and needs to be pulled out / flattened again.
2 - Sheet metal for fender mount is bent in the front. This looks like it should be an easy fix
3 - Tow hook mounting location bent in. I don't care as much about fixing this as a new (unbent ) tow hook should still mount there.
And of course the need to measure/adjust to make sure the rest of the frame is still in alignment.
Old Sep 25, 2006 | 04:29 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Frame Damage Repair Estimate? (Chil709)
looks fixable
Old Sep 25, 2006 | 05:03 AM
De_tour's Avatar
Default Re: Frame Damage Repair Estimate? (BLUE EH3)
I had the same issue getting stuff fixed. I found a shop for 1500$ with a primer fixed my splash gaurds, bumper, fenders, hood, lights, and core support and a new radiator.
Other shops quoted around 4k, Look around it saves good money for future things
Old Sep 26, 2006 | 09:01 PM
Chil709's Avatar
Default Re: Frame Damage Repair Estimate? (wspcivic)
Thanks for the input.
Has anyone had alignment problems with a shop fixing the frame but not putting the parts back on? I'd like to go this route if possible.
Bleakened
Oct 21, 2013 11:26 AM
codyellis
Mar 14, 2010 12:06 AM
layedoutat0psi
Nov 19, 2007 08:11 AM
HCivicSi23
Welding / Fabrication
Oct 4, 2007 06:32 PM
94whtgsr
74
Mar 30, 2004 12:42 PM
