removing engine but dont got a hoist
Old Sep 24, 2006 | 11:32 PM
coreyhayman's Avatar
Default removing engine but dont got a hoist
i dont have an engine hoist and im going to be removing my d16y8 from my 00 civic si, what other ways have you guys done it? the head will already be off and possibly the transmission as well.....how much can say just the block alone weigh?....how do you guys do it without a hoist? drop it from the bottom? but how exactly?
Old Sep 24, 2006 | 11:36 PM
dohcVTECeg2's Avatar
Default Re: removing engine but dont got a hoist (coreyhayman)
you could always roll it out from underneath
Old Sep 24, 2006 | 11:54 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Here:
https://honda-tech.com/zerothre...42742
I'm still the human search engine around here.
Old Sep 25, 2006 | 05:06 AM
VegaS10's Avatar
Awesome write up Invald....
Old Sep 25, 2006 | 07:26 AM
mike1114's Avatar
Default Re: (VegaS10)
I bascially did the same thing.
Lowered motor all the way to the ground (wheels off) onto a thick blanket.
Jacked car up as high as possible, then grabbed blanket corners and dragged motor out from underneath!!!!
Did my buddies prelude motor the same way.
Old Sep 25, 2006 | 07:50 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (mike1114)
Know any bouncer buddies?
When my buddy needed some muscle I called up a friend of mine (350lb 6'5")
He only bench presses 505 and squats 800 something... He grabbed the gsr motor out with two hands and put it on his shoulder. I was 10 different kinds of impressed.
Old Sep 25, 2006 | 07:56 AM
fmrprojects's Avatar
Default Re: (ek forever guy)
whats a d16y8 doing in a civic si?
SkoundrelUSA's Avatar
cute little bastard
When my friend and I took out my B16 (complete with tranny still on). we first jacked the car up as high as possible onto jack stands, put a small dolly, then proceeded to unbolt the mounts and wires and all that crap, and used a jack with a spare donut on it to lower the motor onto the dolly. Then rolled the motor out. A little harder than how I described but not too bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">whats a d16y8 doing in a civic si?</TD></TR></TABLE>
lol I was wondering that too. Probably stolen recovery. This kid I know used to have a D15B8 in a 4 door Integra hahaha
Old Sep 25, 2006 | 08:02 AM
INVALID's Avatar
Not all that observant.
He lives in Canda and that's the engine that's supposed to be in the car.
Old Sep 25, 2006 | 08:04 AM
cute little bastard
Default Re: (INVALID)
ooo right right right right
I forgot
Old Sep 25, 2006 | 08:44 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (fmrprojects)
I was waiting for some jackass to say this. It has nothing to do with the thread.
If you can get your car jacked up high enough you should be able to drag it out the bottom. If all else fails, single cam heads are pretty easy to yank off. You could always pull the head and drag the short block out from underneath. Or you could just go rent one. Not sure how Canada is, but there are tons of tool and equipment rental places where you can rent whatever you need for the hour, 1/2 day, day etc....
Old Sep 25, 2006 | 11:13 AM
dpaton's Avatar
I bought a chain hoist for $30 from a local importer and wrapped some aircraft cable over a rafter in the garage...voila, instant engine hoist.
If you can pull the head, trans, and accessories off (alt, A/C comp, PS pump, etc) then 2 buff guys can probably lift it up and out. If not, lower the engine onto a blanket and jack the front end up as high as you can...you can roll the block over and slide it out.
Old Sep 25, 2006 | 11:35 AM
ej6joe's Avatar
check where he his from, CANADA..there SI is our EX, and soooooo.......therefore explaining....oh just in case there SiR is our SI
Old Sep 25, 2006 | 02:50 PM
Im going to remove the head anyways since its the bottom end thats blown, so i guess i should have no problem lowering the transmission and block out like posted above. Thanks for your help
Old Sep 25, 2006 | 03:40 PM
Boricuanology's Avatar
I just recently did it with a motorcycle jack. you can bring the whole engine and tranny with this baby. You have to put your car in jack as high as possible then use the motorcyble jack to remove the whole thing if you have to. you can use it for your tranny too.
Old Sep 25, 2006 | 06:17 PM
jdmeg61's Avatar
put 2 jacks under each side as low as they will go where they still support the car then put 1 jack under the motor after everything is disconected drop the motor a little easy they raise the 2 jacks up all the way i put a peice of plywood under the motor with rope through it so it woul be easier to pull pull out from the drivers side.... u can avoid all this by just buying a hoist it makes it alot easier it worth the 140.00 or so good luck
Choy
23
Mar 8, 2009 11:08 AM
jaymua
Jan 31, 2009 08:51 PM
KL14
42
Dec 9, 2005 04:28 PM
MALIBULSV
Dec 7, 2004 12:46 PM
